Latest: Beduff1977
Overall: 17134
Online Now [2069]:
Visitors: 2068
Today: 207708
Total: 109774118
Forums › The Car › 206 Talk › mot fail
mot fail
kev85
PostPosted: Tue May 03, 2011 5:28 pm Up
hi everyone. dreaded time has come around again and it failed..although on first look it doesn't seem to bad. car is x reg 2.0 gti
1) nearside w/screen wiper does not clear the w/screen effectively [8.2.2]
2) offside w/screen wiper does not clear the w/screen effectively [8.2.2]
3) w/screen washer provides insufficient washer [8.2.3]
4) nearside headlamp not working on dipped beam [1.7.4a]
5) nearside side repeater not working [1.4.A.2c]
6) offside rear parking brake recording little or no effort [3.7.A.7a]
7) nearside front anti-roll bar linkage has excessive play in a ball joint [2.4.G.3]
Cool parking brake efficiency below requirements [3.7.A.10]
brake failure: RBT park brake efficiency 8%
my interpretation
1) new wiper blade
2) as above
3) ???
4) new bulb
5) new bulb
6) new handbrake cable
7) new n's drop link
Cool new handbrake cable
if any of that is wrong can somebody help me out..been quoted £120 to get it all sorted but if it's only what i think it is i could do it for a lot less than that i imagine.
if this can be done without too much expense it might keep me from selling the car for another year or so. cheers Smile
206 gti sp
ExoVyper
PostPosted: Tue May 03, 2011 5:39 pm Up
3) either no water in the tank, the jets are blocked or arn't pointing onto the screen to supply sufficient water
6) could be it either needs adjusted up or as simple as the shoes have glazed over Smile
and eight is just a validation of 6 so there only a few things to sort really Smile
Bigbenj_08
PostPosted: Tue May 03, 2011 5:46 pm Up
the 1st 5 should have been checked before the MOT anyways!
Aegean Blue 1.6 16v Sport
kev85
PostPosted: Tue May 03, 2011 5:47 pm Up
cheers for that.
3) probably the no water in the tank to be honest, mot was a bit of a rush job so didn't have time to get it fully prepared.
what are the shoes in terms of the handbrake..i tightened it up myself the other day but it's already starting to come loose again so think it may have reached the end of it's life. Sad
206 gti sp
ExoVyper
PostPosted: Tue May 03, 2011 6:47 pm Up
well i'm not sure on the gti's myself so i don't know if they have a disk or drum axle on them.
the shoes are inside the drum so it would need removed ( if they are drum axles)
also what did you tighten up?
MrZiggerz
PostPosted: Tue May 03, 2011 7:16 pm Up
120 is cheap.
MrrNoName
PostPosted: Wed May 04, 2011 2:21 am Up
lol did you not check your wipers and bulbs before you took it in, imagine if it had only failed on that!
iainlovatt
PostPosted: Wed May 04, 2011 2:38 am Up
I agree with that! did you not look at the car and test the basic things before hand?
I would say you could do most of it and only get the garage to do the handbrake and drop link at a cost of £50 probably, + the retest fee if you have to pay it!
(My Garage)
PostPosted: Wed May 04, 2011 2:56 am Up
I would recommend making sure you always keep the washer fluid topped up. Having no washer fluid is actually a moving traffic offence, for which you could be fined. You even risk loosing the car as it could be classed as being in an unroadworthy condition.
Does nobody do weekly checks anymore? fluids, bulbs, wipers, tyres. It takes 5 minutes and can save you loads of hassle.
I haven't done a modern driving test, but I thought this was part of the test nowadays. Seems like for some people it might be "I have my licence, now I won't bother remembering how I got it". Is it any wonder we have so many lunatics on the roads!
gixxerkev
PostPosted: Wed May 04, 2011 3:36 am Up
I do my weekly checks and I totally agree with you macca, seems to me there is a "I've got a car, dad will look after it for me" attitude these days. I taught my son the pitfalls of not doing the weeklys when he got his first car and he still does them 6 years later. Play-station generation eh !!
An Ex '03 1.4 GLX driver, German technology all the way now.
MrrNoName
PostPosted: Wed May 04, 2011 3:40 am Up
that may be true with some drivers, but ive always brought my own cars, done repairs, paid for new parts, done my checks etc etc. so thats not true with all young drivers.
i think the attitude has changed slightly because modern cars dont require such constant checking, with services being frequent fluids are topped up then etc. im not agreeing with people not checking their levels and leaving it all to the service folk, but it does happen more and more.
some people see a car as an object which they get in and use untill it goes wrong, then it goes to the garage and gets fixed
gixxerkev
PostPosted: Wed May 04, 2011 4:10 am Up
Im not saying that all young drivers are the same and I agree with your statement about modern cars not needing as much checking as older cars, but after reading lots of posts on here about various problems and faults it makes sense that if the basic checks were carried out, even once a month, then a lot of money could be saved by lots of Pug owners !!
