Latest: lio94
Overall: 17181
Online Now [171]:
Visitors: 170
Today: 140812
Total: 140937352
Forums › The Car › Solved 206 Problems › Replacement Wing Mirror
jackwetson
PostPosted: Fri Apr 25, 2014 2:49 am Up
I recently ordered a replacement wing mirror for my 206 2.0 Hdi after a cyclist kindly knocked my other off.
As you can see in the picture my current one (still attached) has a white connected, the new one a brown and orange connector. I'm wondering if anyone knows if these are hot swappable if I just cut the leads and reattach in the right order?
The only reason I ask is because the seller is being a pain about returns.
Diagbox available for use in Stroud, Gloucestershire.
omega
PostPosted: Fri Apr 25, 2014 3:25 am Up
don't know
but if you not sure don't buy
1245678
jackwetson
PostPosted: Fri Apr 25, 2014 3:30 am Up
omega wrote:
don't know
With the greatest respect this isn't exactly helpful to the situation. When ordering the part the full chassis number was given so this wasn't a mistake on my part.
copey
PostPosted: Fri Apr 25, 2014 4:19 am Up
jackwetson wrote:
omega wrote:
don't know
then in fairness if it isn't a fit and the guy told you it would ect.....he can't argue about a return
02 2.0 hdi d turbo
jackwetson
PostPosted: Fri Apr 25, 2014 4:26 am Up
I appreciate your comments, but I do know my way around consumer law Smile The question is to if I can make it fit, it'l be quicker for me to use a soldering iron rather than battle out the return.
PostPosted: Fri Apr 25, 2014 6:18 am Up
You could go to Peugeot and buy the adaptor loom, and since they make an adaptor, I can't see any reason you couldn't solder your old plug onto the new mirror. Just be a case of following the wires in each mirror to make sure you connect the right ones together.
Edit. And as if by magic, here's a similar thread
jackwetson
PostPosted: Fri Apr 25, 2014 7:23 am Up
Perfect thank you Smile Couldnt find this when i searched
iainlovatt
PostPosted: Fri Apr 25, 2014 11:13 am Up
Hi mate, yes you can chop the ends of both. However I would get the broken one and cut the end of that and and put it on the new mirror. Dead easy.
(My Garage)
jackwetson
PostPosted: Sat Apr 26, 2014 9:25 am Up
Just finished it all now, 10 minutes of soldering and it works perfectly. Thanks all!
