Posted: Fri Apr 22, 2011 2:52 pm |
ive got the standard clarion cd player in my 206 ive seen on ebay adapters to be able to connect a amplifier to it for a subwoofer. do these work or is there any other way of doing it as i dont really want to change the headunit
| if it dont scuff the ruff it aint low enuf | |
Posted: Fri Apr 22, 2011 3:04 pm |
just buy a speaker wire to phono adapter and wire it to the rear speakres
Posted: Fri Apr 22, 2011 3:05 pm |
will it sound as good as the low tone outputs on after market radios? as im sure speakers are high tone
Posted: Fri Apr 22, 2011 3:07 pm |
Yeah its fine.
The sub just does low frequency, so you can connect it to any output and it will do the same.
Posted: Fri Apr 22, 2011 3:09 pm |
so if i get 2 rca connectors and wire them up to the rear speaker output on the radio end of the loom it should work fine?
