Posted: Wed Apr 20, 2011 6:02 am |
Hello,
I have quick question, it might sound stupid but I`m not very sure so i want to ask you guys.
I found good wheels for sale they are 16" inch but it says 2 FRONTS ARE 205 WITH REARS ARE 195 WIDTH... why is that? I don`t want to be silly but is that how the model comes original?
My other question is I have 206 1.1i yr98 and If i get the 16" Alloys would the car be fine if I lower it by 40mm. I found some cheep springs and im really up for buying them if everything is gonna be fine. I am only replacing the springs
Posted: Wed Apr 20, 2011 6:04 am |
rx3mer wrote: |
Hello,
My other question is I have 206 1.1i yr98 and If i get the 16" Alloys would the car be fine if I lower it by 40mm. I found some cheep springs and im really up for buying them if everything is gonna be fine. I am only replacing the springs  |
Yes you should be fine, maybe just uprate your rear shocks i later on though, i have 17s on mine lowered 40mm and its fine now, bloody caught on wheel arch liner lol
check if they are the same height, i dont think tyre width really matters? but with tyre height it does and can fail mot!
Posted: Wed Apr 20, 2011 7:35 am |
The answer from the guy that sells them:
"the height it the same, and its not a MOT failure unless the are different sizes on the same axel so front and rear can be different there only like that as we used it on a lowered car and stops the rear catching the arch Cheers "
I guess that means 40mm will be fine (happy) !
Posted: Fri Apr 22, 2011 12:52 pm |
Can I request any pictures of -40mm springs on the standard GTi wheels!?
Thinking of lowering mine.
