Online Now [59]:
Visitors: 58
Today: 12100
Total: 106141825
Forums › The Car › 206 Problems › pug 206
pug 206
craig440
PostPosted: Mon Apr 25, 2011 6:58 am Up
pug 206 1.4glx 51 plate hi problem is the car turned over but did not fire up.
my mechanic has changed ecu,bsi ignition barrel,coil pack checked its getting fuel and pressure but its still the same turns but wont fire.was wondering if the ecu etc will need reprogrammed as heard that if everything is changed dosent need reprogrammed.
dont cars give u a headache?
PostPosted: Mon Apr 25, 2011 7:00 am Up
What was wrong with the original BSI & engine ecu then?
Changing parts like this just shouts desperation
craig440
PostPosted: Mon Apr 25, 2011 7:14 am Up
well we tried other things and came to a conclusion that it has to be ecu etc.
PostPosted: Mon Apr 25, 2011 7:21 am Up
What diagnostic tests have been carried out?
Non plexed or multiplexed 206?
Crank sensor checked?
Timing belt checked?
Coil pack?
Spark plugs?
PostPosted: Mon Apr 25, 2011 7:24 am Up
What about the keys?
Is the chip correctly timed with the ecu?
PostPosted: Mon Apr 25, 2011 7:31 am Up
Sounds a lot like the Polish bloke at my work, just keep changing parts till it works Wink Laughing
craig440
PostPosted: Tue May 03, 2011 3:01 am Up
took it to pug dealer for recode say they wont do it as its a different ecu,bsi thats been put in and its illegal...wtf.
