Latest: airmastertapes
Overall: 17133
Online Now [50]:
Visitors: 49
Today: 22400
Total: 106686604
Forums › The Car › 206 Problems › Cooling fan wiring query
Go to page Previous  1, 2, 3
perry081064
PostPosted: Sat May 14, 2011 1:47 pm Up
scousemouse wrote:
check the resistor as for perry;s post wiring to relay is terminal 30 12v from battery
terminal 87 to fan motor
terminal 85 ground terminal 86 from coolant sensor vis air con ecu
in all cases check the fan wiring first and using terminal layout above check relays which leaves coolant temp sensor which if you guage reads correctly will point to the low speed fan resistor
thanks for the info , havent had time to get at it yet but will let you know when i do.
206 2.0 HDI
Page 3 of 3
