Latest: tebas93089
Overall: 17179
Online Now [175]:
Visitors: 174
Today: 53410
Total: 138361375
Forums › The Car › 206 Problems › AC ineffective/ makes squeaking noise
mikewd
PostPosted: Wed Apr 20, 2011 5:32 am Up
Hi,
I have an '05 206 Verve, the dealer said they changed the pollen filters the day before I bought it. I haven't used the air con a lot until recently with the hot weather, but it really struggles to keep the car cold, I am still too hot after 15 minutes of it on full blast.
There is a squeaky noise as soon as I turn the AC on, like when chalk makes a squeak on a chalk board only much quieter. I think this might have something to do with the problem.
Thanks for any suggestions. Service isn't for another few (hot) months!
Mike
2005 verve owner!
copey
PostPosted: Wed Apr 20, 2011 6:44 am Up
if the air con is warm chances are it needs re gassing
02 2.0 hdi d turbo
PostPosted: Wed Apr 20, 2011 9:48 am Up
Once the aircon is working again you need to use it at least once a week else the seals will dry out & the gas will escape Wink
05 car, bet it hasnt been gassed since the factory.
Find your local aircon specalist & let them have a look, AVOID the main dealer! ! !
copey
PostPosted: Wed Apr 20, 2011 12:26 pm Up
i need to get mine re gassed with summer approaching, i do remember somebody on here going to quickfit and getting quite a bad result, with the gas leaking into his cabin
02 2.0 hdi d turbo
PostPosted: Wed Apr 20, 2011 12:29 pm Up
Mines getting a bit low on gas, not been done since summer 2006 Embarassed
AX-Rated
PostPosted: Fri Apr 22, 2011 12:24 pm Up
Why avoid main dealer!? Mine hasn't been done since factory (2003!)
Black 03 GTi
PostPosted: Sat Apr 23, 2011 3:45 am Up
Because an aircon specalists is a better option then letting a main dealer apprentice f*** it up Wink
2003 car not been touched, im shocked the aircon system is still actually working! Shocked
Abzynthe
PostPosted: Sat Apr 23, 2011 4:09 am Up
East Area Rep - Abzynthe
I have no idea if my aircon will work after its regassed :S
There is absolutely no gas in it since the engine swap and i dont think its been touched before then. Engine is from a 1999!
retta
PostPosted: Tue Apr 26, 2011 6:16 am Up
my aircon/climate control is intermittently working - sometimes works, then it squeals and stops, other times it just doesn't start at all. got it looked at and they said it would need the fan replacing and a control unit and board, and re-gassing. haven't got it done yet, just opening the windows at the moment
firedance 206 glx
