Latest: jackrox1992
Overall: 17186
Online Now [1262]:
Visitors: 1261
Today: 134652
Total: 148895892
Forums › The Car › 206 Problems › keyfob/ecu!
keyfob/ecu!
oldbanger2
PostPosted: Thu Apr 28, 2011 9:12 am Up
my central locking is playing up!! sometimes it works when i lock the car & use the dead lock. then when i try & unlock it, it wont unlock! key fob light flashes but no joy! if i open any door manualy the alarm goes off but as soon as i put the key in the ignition & turn it ,alarm goes off & key fob locks/unlocks the car fine untill the next time,SAME PROBLEM..
car is a 99 spec gti two button key fob....its as if the ecu dosnt recognise the key.. anyone know how to fix this probably??
NEW KEY FOB BATTERY FITTED.. Confused Question Rolling Eyes
206 gti
PostPosted: Thu Apr 28, 2011 9:20 am Up
Have you resynced the key fob?
I can help with muxed but never done a pre plex.
oldbanger2
PostPosted: Thu Apr 28, 2011 9:21 am Up
how could it of gone out of sync?/
206 gti
PostPosted: Thu Apr 28, 2011 9:25 am Up
Dropping it can do it, Ford used to do it if you left it without power for more than 2 minutes.
www.206info.co.uk/Foru...c+key.html Thers the how to. Try that and see if it works. If not at least it's one thing discounted.
hwakeford
PostPosted: Thu Apr 28, 2011 9:28 am Up
ooo mine started to do that for about a week.. and then the whole car died and now I'm having the whole ECU rebuilt!
oldbanger2
PostPosted: Fri Apr 29, 2011 1:53 am Up
so my ecu is on its way out??
206 gti
oldbanger2
PostPosted: Mon May 02, 2011 9:11 am Up
ANYONE??
206 gti
PostPosted: Mon May 02, 2011 9:42 am Up
Wouldn't think so. Could be other things causing the problem.
Have you tried re-syncing?
Is the battery definately good (even if new, measure it.)?
oldbanger2
PostPosted: Tue May 03, 2011 4:28 am Up
tried re-syncing that works, but then after its locked for a few min and i try to unlock with button keyfob it wont unlock. i have to do it manually! i open the door & alarm starts going.. i put key in ignition & turn it ,alarm turns off.. key then locks/deadlocks/ opens the car..leave it 20 min.. keyfob buttons wont unlock car...battery is new....
206 gti
PostPosted: Tue May 03, 2011 5:40 am Up
oldbanger2 wrote:
battery is new....
Might be a dud.
Was it doing it before change of battery? If so its not that.
Clutching at straws but is your keyfob OK? Try with a mate's keyfob if available (sync it).
PostPosted: Tue May 03, 2011 10:32 am Up
Need Peugeot Planet to code a keyfob to a different car Wink
You cant sync a keyfob unless it has already been coded to the car in question BSI unit.
oldbanger2
PostPosted: Tue May 03, 2011 11:49 am Up
it has been working fine ,just started playing up 2month ago, thought it was battery , new one fitted still playing up..
& yes it just started doing it before i got new battery..
206 gti
PostPosted: Tue May 03, 2011 12:17 pm Up
Ah yes. That would make sense otherwise zero security.
Scratch that.
PostPosted: Tue May 03, 2011 12:19 pm Up
You also need the 4 digit alphanumeric security code before the BSI will even allow any keys / remotes to be coded.
PostPosted: Tue May 03, 2011 12:24 pm Up
Lee knows it. Laughing
