Online Now [574]:
Visitors: 573
Today: 14777
Total: 146717870
Forums › The Car › 206 Problems › Splitting Driveshafts....
sonicscrewdriver
PostPosted: Fri Apr 29, 2011 3:58 pm Up
ive just bought a new outer CV joint for the nearside shaft, any ideas how to remove the old 1? im talking bout the actual joint itself not the boot, incase they were mixed up.......
206gti breaking
long time since being on here last! what happened?! lol
cartoonhead
PostPosted: Fri Apr 29, 2011 4:07 pm Up
inside all the grease under boot rubber in one of the brearing grooves there's a sir clip that needs to be opened up a little and the end will slide off.
sonicscrewdriver
PostPosted: Fri Apr 29, 2011 4:21 pm Up
thats the inner joint....the outer joint is attached to the cv cup, tried giving it a 'dai tap' with the hammer but shes on tight!
206gti breaking
cartoonhead
PostPosted: Fri Apr 29, 2011 5:30 pm Up
when you get it off get a pic up as i wanna see what the differance is as i allways assumed that the shaft its self is just a bar with splines and sir clip in the cv for both ends.
