Posted: Wed May 04, 2011 1:36 pm |
I used to have 206 gti but sold it as i couldnt afford to run it annnd it was broken! Circumstances have changed and am buying a 206cc butttt i cant decide between petrol or diesel little help please!? x
Posted: Wed May 04, 2011 1:38 pm |
There are very few diesel 206cc's!
Posted: Wed May 04, 2011 1:40 pm |
Edward wrote: |
There are very few diesel 206cc's! |
I didn't even realise they did 206CC diesels
Ive found quite a few on autotrader at the moment actually!!
I found a few. 22 nationally. 965 petrols! So pretty rare.
Posted: Wed May 04, 2011 1:41 pm |
Edward wrote: |
They only ones Peugeot did do come with the FAPTASTIC 1.6 HDI lump as well
Posted: Wed May 04, 2011 1:44 pm |
Edward wrote: |
I found a few. 22 nationally. 965 petrols! So pretty rare. |
I am aware there are few of them... 22 i only need one!
Posted: Wed May 04, 2011 1:47 pm |
Kel E get a petrol one
MrBSI wrote: |
Edward wrote: |
They only ones Peugeot did do come with the FAPTASTIC 1.6 HDI lump as well |
This means!?
Good luck in finding ONE locally then. You won't have a big choice put it that way.
Posted: Wed May 04, 2011 1:48 pm |
Ali_H wrote: |
Kel E get a petrol one |
I drive quite far to work! But petrol is moe fun! Im confuuused
Posted: Wed May 04, 2011 1:49 pm |
A 1.6 won't cost as much as your GTi tho.
-xkellatronx- wrote: |
MrBSI wrote: |
Edward wrote: |
This means!? |
The 1.6 HDI engine is the worse engine you could have fitted to a 206
The 2.0 hdi is the best diesel engine choice, you cant get it in a 206 CC though.
Posted: Wed May 04, 2011 1:50 pm |
Edward wrote: |
Good luck in finding ONE locally then. You won't have a big choice put it that way. |
Thanks for the useful help if u'd like to call it that!?
I asked a simple question and you proceeded to b sarcastic and had to prove there arent many of them, well done u know how to use auto trader have a gold star!
Posted: Wed May 04, 2011 1:53 pm |
MrBSI wrote: |
MrBSI wrote: |
Edward wrote: |
This means!? |
The 2.0 hdi is the best diesel engine choice, you cant get it in a 206 CC though. |
Thank u for the warning!
