Latest: Beduff1977
Overall: 17134
Online Now [566]:
Visitors: 565
Today: 125644
Total: 108941447
Forums › The Car › 206 Problems › Floppy indicator fix? Com2000.
stevesey
PostPosted: Sun May 01, 2011 11:31 am Up
We have the usual floppy indicator problem (cancels too easily and goes from right to left when canceling after a corner).
Reading this: www.406oc.co.uk/viewto...f=3&t=7635
Electrically all is fine so I'm tempted to take the com2000 out and have a look at the mechanicals. So couple of questions:
a) Has anyone tried this?
b) Anyone have a dead com2000 I could have a look at first? (Will pay P&P of course - or pick up from Bristol/Swindon).
Results will of course be shared.
Cheers
Steve
PostPosted: Sun May 01, 2011 11:36 am Up
Just strip it apart, it not hard and its straight forward. Only need a flat bladed screw driver
stevesey
PostPosted: Sun May 01, 2011 11:49 am Up
Thanks Lee - do you know if streching/padding the spring or similar can fix it. Given how expenive they are I'm suprised has investigated further and produced a how to (here or elsewhere). Or are people just frightened of the amount of disassembly (of airbags/electronics) in order to get to the mechanical bits to fix it.
PostPosted: Sun May 01, 2011 11:51 am Up
Id much rather just put a new replacement com on with a warranty, there cheap enough if you look in the right places Wink
The original com units where poorly made, no wonder PSA Peugeot / Citroen found a different supplier Wink
stevesey
PostPosted: Sun May 01, 2011 12:22 pm Up
Obviously I'm not looking the in the right places Confused can't see much below £100.
PostPosted: Sun May 01, 2011 12:45 pm Up
Just clean it all up, check the contacts, freshen up the grease. Thing springs in pens are the same or similar.
stevesey
PostPosted: Sun May 01, 2011 1:21 pm Up
Will do - my daughter is away the week of the 22nd May - planning to do then. Will report back.
dumdum0910
PostPosted: Mon May 02, 2011 3:16 pm Up
keep us posted on this fella and do a strip down pic as im needing to do mine aswell
stevesey
PostPosted: Tue May 24, 2011 2:02 pm Up
Removed and stripped down according to the instructions on the 406 site. Any grease on the indicator mechanism had gone waxy, so freshened up with some silicon grease. Removed spring and padded out with a small piece of rubber dropped in the end of the recess. Indicators seem much more positive and seem to cancel properly - will put back in car tomorrow and see how it goes.
stevesey
PostPosted: Wed May 25, 2011 5:43 am Up
Re-fitted and....
no change really Sad . Despite feeling more solid - it will still go right to left when cancelling.
Think I have made a slight difference though as when combined with the foam fix (http://www.youtube.com/watch?v=hBBeRvig-tw) it does seem better than it was before (only time will tell). Almost perfect even - certainly liveable with.
I modified the foam fix slightly my just cutting a slot and pushing the foam over the stalk. This seems to work damping the stalk movement, but not adding any tension when in the left/right position as the stalk can move in the slit.
