Latest: tc.206
Overall: 17147
Online Now [169]:
Visitors: 168
Today: 17759
Total: 116302133
Forums › The Car › 206 Talk › So.... my wheel fell off
craigy00craig
PostPosted: Tue May 03, 2011 5:29 am Up
Yeh my f*****g wheel fell off!!! I took the wheels off the paint the calipers. Started driving home from my friends and started hearding this juddering noise so i pulled over and checked all the wheel nuts and all seemed fine. So went to perform a 3 point turn and crash, the front passenger wheel is no longer attached to the car. Wing slams against the tyre and knocks it totally out of place.
managed to jack it up to put the wheel back on but all the bolts were f****d. Took one bolt off each other wheel but he internal thread was broken so i couldnt get the bolts to screw in.
gonna need a new thing that the bolts screw in, anyone know what that part is called? im going to the local car breakers later so should get a new part and get it fitted.
school boy Sad
Progress Threads:
Danw_VVT
PostPosted: Tue May 03, 2011 5:34 am Up
hub.
craigy00craig
PostPosted: Tue May 03, 2011 5:36 am Up
cheers dude
Progress Threads:
front wheel hub. that's what you need.
doubt you can use a second hand one as the bearing will be destroy when remove.
have you got the pics of the bolts and hubs?
sounds odd that would happen
Danw_VVT
PostPosted: Tue May 03, 2011 5:37 am Up
im guessing it had the worng bolts in for the thread to be gone. where they aftermarket ones?
craigy00craig
PostPosted: Tue May 03, 2011 5:41 am Up
yer they were aftermarket ones but ive had them on there for ages. I think them the wheel was in the process was falling off it just f****d it up... i dunno.
oh s**t so i cant get a second hand hub?? Sad erm nah i dont have any pics, i will take some later
Progress Threads:
Seb
Staff - Seb
I'm guessing then that you didn't quite tighten them back up properly?
You'll probably need a new hub, and it would be worth checking all the suspension components are ok.
colinn
PostPosted: Tue May 03, 2011 5:45 am Up
I had to replace a front hub last year because one of the internal threads got knackered - I got the whole hub/bearing assembly second hand off one of those on-line breakers networks - about £40 iirc - then a local garage only charged £20 to put it in.
MrrNoName
PostPosted: Tue May 03, 2011 5:48 am Up
aww sorry to hear that dude Sad hope there's not much damage, look on the bright side, it could have come off doing 70!
craigy00craig
PostPosted: Tue May 03, 2011 5:49 am Up
awesome, hope i can be as fortunate to get a bargain like that
Progress Threads:
craigy00craig
PostPosted: Tue May 03, 2011 5:51 am Up
cheers. Yeh i was going down an A road going 60 when i started to hear it, luckily i turned off to a residential area, could have ended badly if i didnt :s
Progress Threads:
PostPosted: Tue May 03, 2011 5:52 am Up
you can get a new hubs for 60, fitting is dead easy too.
skard
PostPosted: Tue May 03, 2011 5:53 am Up
i got a whole strut setup (shocker, top mount, spring, hub assembly etc) from a scrappies for £15 last year, only a few bolts to remove it all and a bar to get the bottom balljoint out.
did me for a few days just to get the car back on the road, but you could use it until it needs replaced naturally.
PostPosted: Tue May 03, 2011 5:54 am Up
is probably dur to those cowboy tyre fitter who use airgun to destroy the hubs and the bolts
MrrNoName
i recon this is why it happened.
you did the bolts up, started to drive, they became loose and the wheel was loose and wobbely pushing out on the bolts, you pulled over and checked them but as the wheel was pushing against the bolts and the car wasnt jacked up they felt tight even though they wernt fully in (because the wheel was on the ground so couldnt freely move back against the hub). u started driving again and they came off.
i have no idea if the wheel should be off the ground when you check the bolts, but i duno what else could have caused that?? its kinda worrying lol
