Only when started from cold sounds like it's running on 3 cylinders after 10- 20 seconds it clears and runs normal
I've read the codes and there are none stored
I've changed the plugs and the coil pack but made no difference
once the missfire clears car runs perfect and when started from warm it is fine
anyone got any ideas ?
it's an 2003 1.4i 206sw with a TU3JP engine
| | ![](images/spacer.gif) |
