Posted: Sun Apr 17, 2011 10:44 am |
Well when i reversed off the drive i used to get a clunk noise coming from the rear of the car and i was told it could be the bearings and it was cheaper to replace the axle
sooooo i bought a rear axle, haven't fitted it but the car has stopped doing the clunking noise........
If my bearing(s) had gone would this happen? Why has the noise now gone? I'm now unsure if i should replace the axle or sell it on?
Posted: Sun Apr 17, 2011 11:12 am |
Sell it on ..... to me!
| 206 GTI, Ram air filter, lowered 35mm front, 50mm rear, Scorpion 3.5" Back box, phase 2 boot strip, m3 rear lights.. Not much more i want to do, just sorting the paint work out! | |
Posted: Sun Apr 17, 2011 11:40 am |
you sure the cluck noise is not because of the sticky drum brake?
Posted: Sun Apr 17, 2011 12:02 pm |
i have rear calipers on mine.
i just don't know why the clunking would stop?
Posted: Sun Apr 17, 2011 12:17 pm |
I've got a clunking noise on my XSi and I've had the bearing checked on the passenger side as thats where the noise is coming from and everything else and there's nothing their that could be causing a problems. I don't understand as my cars only 20k miles :S
But mine goes once I get over 30mph.
Posted: Sun Apr 17, 2011 12:49 pm |
I didn't think wheel bearing were that expensive anyway :\ surely they're cheaper than a new axle?!
I'm sure a front one was only £25 ish!
| China Blue 2.0 HDi DTurbo
-Sports Bumpers -Rear Spoiler -Rear Lexus Lights -SP Fuel Cap -SP Bonnet Vent -SP Upper Grille -SP Lower Grille (Zunsport) -Crystals | |
Posted: Sun Apr 17, 2011 1:23 pm |
Mine use to clunk until a friend driving behind me said my wheel was wobbling! Got it up on a ramp and there was a lot of play on the drivers side rear wheel, had to get a new tracking arm and bush I think (mechanic done it all but has bad English) £250 later and it feels like a different car!
I'm just lucky that my friend saw it, get it up on a ramp and get it checked just incase!
| You never really learn to swear until you learn to drive | |
Posted: Wed May 04, 2011 12:07 pm |
Uz wrote: |
But mine goes once I get over 30mph. |
is it the spare wheel brace?
Posted: Wed May 04, 2011 1:01 pm |
dampers fully secure??
| Image removed due to size
Team, ST
Team, Gti 138 track slag | |
Posted: Wed May 04, 2011 1:18 pm |
Mine does this every morning recently, brake pad is slightly binding on rear.
