Posted: Wed May 04, 2011 11:08 am |
had squeaky breaks for few month now, quite loud, coming from front right wheel. peugeot told me its just normal woth french cars? it even squeaks at 30mph if.i.just dab the breaks. car is a xsi 04 . pleaee help
Posted: Wed May 04, 2011 11:19 am |
are they low??
Posted: Wed May 04, 2011 11:22 am |
Glazed pads. Take them out, rough them up with course glass paper, rub the paper over both sides of the disc, refit pads using copper slip on the back and in the sliders where they make contact with the caliper. Usually solves a squeal.
Posted: Wed May 04, 2011 11:23 am |
Cheap pads fitted?
OR
Might just need the front brakes cleaning & then a little dab of copper grease in the right place on reasembly.
While its apart check the caliper slide pins are free.
Must be something wrong with my 206 as my front brakes dont squeak
Brembo when it wants discs
Ferodo Premier when it wants pads.
You chould have the 266mm x 22mm vented front brake set up.
Posted: Wed May 04, 2011 11:27 am |
as said above, glazed pads because they wernt burnished properly when fitted.
Any work you undertake as a result of my posts is done so at your own risk  | |
Posted: Wed May 04, 2011 11:36 am |
MrBSI wrote: |
Don't worry, they will.
Posted: Wed May 04, 2011 11:49 am |
V9977 wrote: |
MrBSI wrote: |
Don't worry, they will.  |
Well they havent squeaked in 6 years so far
Posted: Wed May 04, 2011 11:51 am |
o hell lol. how much is the brembo set up lol? the pads are pug ones on front, been on since i got car at 14k miles now its 30k
