Forums › The Car › 206 Problems › Code P0413 - air fault |
Posted: Wed May 04, 2011 6:03 am |
Good afternoon,
Wanted some advise and opinions if possible.
I've had two seperate code readings. Both bringing up code P0413.
One of the pictures below, shows a broken "air hose". Which from Peugeot is £41.
My issue or question is - I DO NOT have the standard air filter or box at all, I have a silly cone filter.
Sooo, isit worth me buying a air hose? Where does it actually connect to? From the Service Box pictures, it looks as if there'd be no point in me replacing it, as it'll still be an open circuit?
Any other 180 owner's using a non-standard air filter?
| 206 GTi 180 - 406 brembos with 283mm discs, coilovers and Sparco bucket seats | |
Posted: Wed May 04, 2011 9:07 am |
Can anybody post up a few pictures of 180 engine bays please?
