Latest: Stu-mill
Overall: 17131
Online Now [554]:
Visitors: 553
Today: 53443
Total: 104862284
Forums › The Car › 206 Talk › Would this induction kit fit my car?
Go to page Previous  1, 2
acotton21
PostPosted: Fri May 06, 2011 7:16 am Up
K&N filter
Is this one good then?
Davels
PostPosted: Fri May 06, 2011 7:26 am Up
yeah thats the one, just get the right one for your car.
K&N are a big realible firm that have been making filters for years.
As said before the box is designed for mass production and for the most practical and relaible means of delivering air without debris or water being sucked at the same time. (water a particular risk with a cone) That said check for any flaps or anything in the box it self or the air ducting and remove so there is a smooth air path. Then pop your filter in and bob's your aunty.
The box itself it actually insulated well too so you will be sucking in cool air without the engine heating it up. (Cold air burns better than hot air as it has higher o2 content)
acotton21
PostPosted: Fri May 06, 2011 7:30 am Up
Click
So this one is the one i should buy then?
Thanks for all your help Smile
Andrew
PostPosted: Fri May 06, 2011 2:09 pm Up
Yes thats the right one Smile
Glad you made the choice to stay with the standard box, I always think if open cones and these ram air filters were better they would come as standard
My 206 thread
www.detailedbyandrew.com
Davels
PostPosted: Sat May 07, 2011 2:42 am Up
Yeah, sorry for the lack of reply, ebay links are blocked at work and my phone was dead, that's the right one tho by the looks of it as said above.
If you have a good flow of air routed through you can see some gains from an open cone but for normal road use and traffic the air around the cone will be hot as hell.
tracks use with constant movement and cool air flow = no heat soak.
Page 2 of 2
