Latest: Kifi69
Overall: 17183
Online Now [328]:
Visitors: 327
Today: 10993
Total: 144028914
Forums › The Car › 206 Talk › Nimrod Offset
Nimrod Offset
MrrNoName
PostPosted: Mon May 09, 2011 2:35 am Up
anyone know the best way to measure nimrod offset? ive got a bunch of them and some might be 406 and some are 206 lol, have no idea how to tell
PostPosted: Mon May 09, 2011 2:53 am Up
Normally stamped on the alloy
Uz
PostPosted: Mon May 09, 2011 2:54 am Up
On the inside face of the wheels will be stamps, if you jot down all the stamp into and post it up or pm me bud I'll tell you what car each wheel has come from. it should say 4108-25 for 206 and 4108-15 for 406. there are difference in part numbers as well so watch those up. It will be 4 digit and full stop and then 2 digits usually has a character after the dot.
MrrNoName
PostPosted: Mon May 09, 2011 4:55 am Up
ok heres everything which is said on a wheel lol:
On the inside of the spokes:
1: there are 2 circles, 1 is blank the other has 'A' written in it
2: there are 3 circles with 3 letters, 1 stamped next to each circle
Top circle has 'FU' in it and 'F' written next to it
Middle has 'XK' in it and 'X' next to it
Bottom has 'MU' in it and 'S' next to it
3: spoke 3 has two circles on it, one with 'E' in it and 'E' next to it, and the other with '30' in it and 'C' next to it, spoke 3 also has '03' stamped on it
4: spoke 4 has two circles on it, one with 'AU' in it, the other with '85' in it. spoke 4 also has TTH stamped on it
5: SRF 7 stamped on it
6: 'MADE IN FRANCE' (lol)
7: OURAGAN 16 - 2
8: 9640384180
9: spoke 9 is blank
on the actual backing plate of the wheel
6.5J x 16H2
4 - 20
9606 - YJ
PE 14/ 1 A
thats everything on the wheel, do any of those show the offset in code lol?
im used to ET= haha Smile
MrrNoName
PostPosted: Mon May 09, 2011 5:22 am Up
ive since noticed that some have a slightly thicker backing plate then others, im guessing the thicker backing plate reduces the offset (to make the connection closer to the centre of the wheel) so they are 406?
qwert
PostPosted: Mon May 09, 2011 6:15 am Up
20
brum brum
