Latest: tebas93089
Overall: 17179
Online Now [104]:
Visitors: 102
Bots: 2
Today: 20928
Total: 138122855
Forums › The Car › 206 Problems › GTI Low power after oil pressure issue
rangemonkey
PostPosted: Sat Apr 30, 2011 3:34 pm Up
Driving along yesterday both my Low oil pressure & low brake fluid warning lights came on, along with the STOP warning light. When I pulled over I discovered that the oil was very low & topped it up. All of the warning lights disappeared when i topped the oil back up to the correct level.
However upon restarting the car the accelerator pedal has very little travel & the engine will not rev past 3000 rpm. Is this the ECU in some sort of 'Safe' mode to protect the engine? or something else?
If it is the ECU in safe mode is there a way to reset this?
Mmmmmm...............
-Dave-
PostPosted: Sat Apr 30, 2011 3:36 pm Up
Trade Rating: +36
Search Limp Mode, I think you should find your answer somewhere on here.
Ex 206 Owner.
kieron
PostPosted: Sat Apr 30, 2011 3:38 pm Up
it will need to be hooked up to a scanner to clear the fault code
Account suspended
rangemonkey
PostPosted: Fri May 06, 2011 7:32 am Up
Thanks Guys. Just as i thought. Does anyone one know anywhere in Surrey that will clear this type of problem without wanting too much cash? based in Camberley so could look at place in North Hants & Berkshire too.
PostPosted: Fri May 06, 2011 10:02 am Up
So you were under the bonnet and now the throttle won't move much? Check out the cable under the bonnet. Have you knocked the clip that keeps it in position?
rangemonkey
PostPosted: Sun May 08, 2011 4:46 am Up
Thanks, yep the clip had disappeared so with the cable re-adjusted the car is running fine again.
PostPosted: Sun May 08, 2011 5:35 am Up
It was obvious enough.
