Posted: Sun May 08, 2011 9:46 am |
Haha a set of plugs will not fry an ecu.
They only spark to combust fuel for god sake worst case - Engine management light and go to get me home mode.
I seriously doubt a company like NGK will manufacture plugs that are incompatible with an engine. Cumon guys wake up!
| 206 180 rally car in progress. I may not be perfect but there are parts of me that are f£%$ing brilliant | |
Posted: Sun May 08, 2011 9:51 am |
| imjeeves wrote: |
I seriously doubt a company like NGK will manufacture plugs that are incompatible with an engine. Cumon guys wake up! |
Go do your homework & come back again with the CORRECT answer
If a company the size of PSA Peugeot / Citroen sends out a technical service bulletin to its entire dealer network warning about NGK spark plugs then you must know something that PSA dont
Posted: Sun May 08, 2011 10:01 am |
Ok MR BSI clearly your ability to read a message on the service box has made you a technical expert on the subject of sparkplugs and the Peugeot / Citroen group and the technical problems with there cars.
Wouldn't be the fact that our good friend Mr Peugeot has a contract with Bosch for all their cars no??
Always used NGK and always will do and some know it all t**t on a forum aint going to change that. Ran Peugeot for years on NGK's and not EVER had a problem
Posted: Sun May 08, 2011 10:05 am |
| imjeeves wrote: |
Always used NGK and always will do and some know it all t**t on a forum aint going to change that. Ran Peugeot for years on NGK's and not EVER had a problem |
Try the phase detection system PSA designed in to the coil pack to detect any misfires happening being incompatible with the design of NGK spark plugs.
This can lead to the HT voltage instead of firing the spark plug being backfed down the wiring loom & finding its way to the engine ecu which in turn frys it.
Eyquem, Bosch & Champion supply spark plugs to PSA Peugeot / Citroen
Keep fitting your NGK's if your such a fanboy
Posted: Sun May 08, 2011 10:09 am |
i always fit genuine peugeot ones then a know it will be fine
Posted: Sun May 08, 2011 10:12 am |
I used Bosch Super Plus last time as there cheap on the trade card.
Posted: Sun May 08, 2011 10:18 am |
So... Fuel filters
Yeah it's a self-cleaning one, so won't need replacing for a long time
Whats a long time????
| drive fast !!! live life faster !!! | |
Posted: Sun May 08, 2011 10:47 am |
The life time off the car unless it gets contaminated.
| Image removed due to size
focus st 3 with pro alloy intercooler, 3" mongoose down pipe, 200 cell sports cat and mongoose cat back, collins bov, dreamscience dsci cold air intake,focus rs injectors,focus rs oil cooler,dreamscience dsci tuneing platform mod X map,focus rs clutch & flywheel, rs fuel pump, polly bushes in wish bones rear axal and suspension white line front and rear arb, eibach pro street s suspension. | |
Posted: Sun May 08, 2011 10:51 am |
rite so nothing to do spot on !!!!
Posted: Sun May 08, 2011 10:55 am |
If I was u would change the plugs. Try cleaning the map sensor. Clean the tb. Then come back to us with results mate.
Posted: Sun May 08, 2011 10:56 am |
cheers nick spot on dude
