Posted: Sun May 08, 2011 7:20 am |
My air con ran out end of last summer, and i had no money to have it re-gased, but i've been given the chance to have it re-gased at work for free. But when i press the air con button nothing happens.
Is this because the compressor is broken, or is it a safety feature that when i re-gas the system it will work again?
| Moonstone blue 206 1.4look
pro race 1.2 White
Morettes
GTI wings
TEAM: Carbon Fibre
TEAM: I'm a greedy jelly fiend! | |
Posted: Sun May 08, 2011 7:21 am |
Yeah should be fine when regassed
Posted: Sun May 08, 2011 7:22 am |
Ermmm, i think either a fuse has popped or the compressor is broked
| Team Impossible Possible
Posted: Sun May 08, 2011 7:32 am |
Well the fuse hasn't gone, is there any way of checking the compressor? or is it a case of i'm not going to know until it's re-gased?
pro race 1.2 White
Morettes
GTI wings
TEAM: Carbon Fibre
Posted: Sun May 08, 2011 7:48 am |
It's free Get it done and see if it then works.
Posted: Sun May 08, 2011 7:57 am |
Edit: When they re-gas it get them to fix the leak too. Most companies just put refrigerant back in without fixing the leak for it to come out again.
Posted: Sun May 08, 2011 7:59 am |
Mine had this same problem GG, had it re-gassed and its working fine now.
Posted: Sun May 08, 2011 8:02 am |
Thanks guys, i will take it and re-gas it tonight and hope it works, as i can't afford for the compressor to have gone
pro race 1.2 White
Morettes
GTI wings
TEAM: Carbon Fibre
Posted: Sun May 08, 2011 8:04 am |
Mrs_Howey wrote: |
Thanks guys, i will take it and re-gas it tonight and hope it works, as i can't afford for the compressor to have gone  |
I have one spare?
Thanks adam if it's gone i will send you a pm
pro race 1.2 White
Morettes
GTI wings
TEAM: Carbon Fibre
Posted: Sun May 08, 2011 8:32 am |
just for clarification though , if indeed there is no gas in the aircon , would the fan still kick in once activated anyway ?
Posted: Sun May 08, 2011 8:35 am |
perry081064 wrote: |
just for clarification though , if indeed there is no gas in the aircon , would the fan still kick in once activated anyway ? |
Should do mate
Posted: Sun May 08, 2011 8:49 am |
Addaz wrote: |
Should do mate |
fan wirings still knackered then
cheers
Posted: Sun May 08, 2011 9:28 am |
No if you have no gas in the system the air con fan will not kick in, I had the same problem which I thought I was looking at a big bill for but no had the air con re-gassed and it works fine.
So to clear things up, if there is no gas in the system the air con will not activate.
Posted: Sun May 08, 2011 9:31 am |
Mikey2uk wrote: |
So to clear things up, if there is no gas in the system the air con will not activate. |
Ignore me then
Im cracking up
