Posted: Mon May 09, 2011 8:49 am |
Wanting to paint my fuel cap, got an aftermarket GT style metal one. What black paint do you think would be best as in what type?
Cheers
Dulux.
Posted: Mon May 09, 2011 8:50 am |
Posted: Mon May 09, 2011 8:56 am |
No seriously, im new to this. I know spray paint but what types the best to use? How many coats?
Posted: Mon May 09, 2011 8:59 am |
use a primer after keying the surface etc then normal car spray paint and some good lacquer!
Posted: Mon May 09, 2011 9:01 am |
I done mine, you will get the best quality by sanding thoroughly with 600ish grade sandpaper, then 3 light coats of etch primer, dry sand with 1000 grade, 3 or 4 light coats of colour (halfords can will do) sanding 2000 grit inbetween coats that have been allowed to fully dry, then 3 coats of lacquer, 2000 grit on the final outcome and use a good polish
Posted: Mon May 09, 2011 10:32 am |
If you want a plain glossy black use hammerite smooth in spray form. Its good stuff and you don't need to primer or anything. Thats the easy and idiot proof way
Posted: Tue May 10, 2011 4:04 am |
Rob2859 wrote: |
If you want a plain glossy black use hammerite smooth in spray form. Its good stuff and you don't need to primer or anything. Thats the easy and idiot proof way |
Cheers, yeh I think ill try this way sounds simplest.
