Online Now [298]:
Visitors: 297
Today: 78141
Total: 106272301
Forums › The Car › 206 Problems › Cambelt tensioning 1.1 2002 onwards
stevesey
PostPosted: Mon May 09, 2011 1:04 pm Up
I see that 2002 onwards engines were fitted with an "automatic" tensioner.
What's the difference in the fitting procedure to the manual version outlined in the Haynes manual and the how-to on here. I assume fit belt, release tension, turn engine a couple of full rotations buy hand and check tension. But no adjustment as such?
Cheers
Steve
imjeeves
PostPosted: Mon May 09, 2011 3:41 pm Up
Think you are talking about a dynamic tensioner
Just had a spring loaded system that locks against a lug on the block. The arrow on the tensioner is aligned with the slot on the tensioner and job done.
The tensioner moves back and forward to apply the correct tension to the belt
stevesey
PostPosted: Tue May 10, 2011 10:59 am Up
Yes that's the type - is this the same as the 1.4 16V engine (which haynes does describe = same block aren't they?)
