Latest: tbafonso
Overall: 17130
Online Now [234]:
Visitors: 234
Today: 29226
Total: 104561024
Forums › The Car › 206 Problems › radiator
radiator
tommo1000
PostPosted: Tue May 10, 2011 3:11 pm Up
can anyone tell me what`s the purpose of the small rubber pipe that sits in the bottom left of the radiator near the alternator and water pump,i put my car on the ramp this aft to examine a split in the top of it and found it`s just basically an inch rubber hose with a blocked end(a bit like a bung)with a jubilee clip on it,it does`not lead anywhere,im`e of the opinion that it`s some kind of venting point and somewhere along the line it`s been bodged by blocking it up ??
rovers4eva
PostPosted: Tue May 10, 2011 3:13 pm Up
drain plug/ pipe i think
PostPosted: Tue May 10, 2011 3:37 pm Up
Near the water pump and alternator??? You got any pictures? It sounds a bit unusual if it's coming from the radiator.
tommo1000
PostPosted: Tue May 10, 2011 3:38 pm Up
makes sense,drips like a ***** for about 5 minutes when i turn the engine off,another thing to fix,i shall be busy this friday Smile
rovers4eva
