Latest: tbafonso
Overall: 17130
Online Now [324]:
Visitors: 323
Today: 35829
Total: 103080607
Forums › The Car › 206 Problems › Dial problem
Dial problem
Mowle5677
PostPosted: Mon May 16, 2011 6:32 am Up
Okay I finally brought a set of lockwood dial and have fitted them with the help from the Haynes max power book but the problem is when I fit the cluster into the car them temp and fuel gauge shoots up off the gauge!! Can someone help me please
Can't wait to take the car to it's first show Smile
Jay794
PostPosted: Mon May 16, 2011 7:21 am Up
Could be 1 of 2 things:
Either you must have span the dial to many times when removing them
Or
You simply put them back in the wrong place e.g putting the fuel needle on full when in fact the tank is empty.
The first one will result in new cluster, the second problem just means you'll need to put the needle back in the right place
Mowle5677
PostPosted: Mon May 16, 2011 7:37 am Up
How do I correct it then? The cluster wasn't on the car when I put the new backing in.
Jay794
PostPosted: Mon May 16, 2011 8:10 am Up
Well did you make a note of how much fuel you had in the car before removing the dials. The Stuff you should have noted was:
Idling position for revs
fuel level
oil temp when idling (if you have oil temp)
Engine temp (usually around 90)
To fix it you have to pull the needles off and put them back in the right place
Mowle5677
PostPosted: Mon May 16, 2011 8:13 am Up
No I didn't I just put it all back to the bottom!
Mowle5677
PostPosted: Mon May 16, 2011 12:46 pm Up
Anyone in the surrey area that can help me out?
Rob2859
PostPosted: Mon May 16, 2011 5:34 pm Up
make sure they are pushed in all the way. I got this because I didn't put them on tight enough
Mowle5677
PostPosted: Tue May 17, 2011 1:25 am Up
They are pushed all the way in but I'm really stuck on how to fix it with out getting another set of dials
