Latest: sparrowdclxvi
Overall: 17139
Online Now [230]:
Visitors: 229
Today: 2520
Total: 113123986
Forums › The Car › 206 Talk › Are these the Coolant Bleed Points? (Pic's)
finners
PostPosted: Mon May 16, 2011 6:53 am Up
Guys,
I have just drained the coolant on the car and refilled it using this guide: -
my206xr.blogspot.com/2...iator.html
(I hope its ok to link to guides outside of this forum btw, if not tell me I will delete it)
Anyroad I just wanted to confirm that I am using the correct bleed points: -
This one on the heater matrix
& this one on top of the thermostat housing.
I have to say I dont think I got 6 litres of coolant when I drained it more like 4 - 5 litres.
I seem to have only put about 3 litres in. Can someone conform the quantity that goes into these cars as it dont say in the Peugeot manual.
206 5 DOOR ESTATE 1.4i 75 (TU3JP) Manual gearbox 5 - 54 Plate
MrrNoName
PostPosted: Mon May 16, 2011 6:59 am Up
less went in because there's probs air pockets all over the system Smile
slightly off topic but look at pic 7 of that guide! there's water literally flowing over the electrics... bad idea, water and engine electrics really really dont mix lol
finners
PostPosted: Mon May 16, 2011 7:03 am Up
Yeah I did notice the water puring onto the electrics, I tried to protect them as best I could when I did it.
Are you able to confirm that those are the two bleed points?
MrrNoName
PostPosted: Mon May 16, 2011 7:04 am Up
sorry i dont know, im planning to do this myself next week so would like to know though Smile
Make sure the heater controls are set to hot & run the engine with the filler cap off for a while to help bleed the system.
finners
PostPosted: Mon May 16, 2011 7:08 am Up
I'll give it a go cheers
leon206
PostPosted: Mon May 16, 2011 7:10 am Up
OFF TOPIC. this guy removed the air filter intlet box totally for increased throttle response, etc . is that ok just in case of water ingree/ foreign objects piercing air filter and getting into the engine?
my206xr.blogspot.com/s...r%20Filter
peugeot
gixxerkev
PostPosted: Mon May 16, 2011 7:15 am Up
Ive drained my engine/rad and only used the heater drain point (pic 1) as its the highest point. As said above put the heater controls to max hot and run the engine. It might take a couple of goes to completly fill the system as any air locks get "flushed out" so to speak.
An Ex '03 1.4 GLX driver, German technology all the way now.
Danny.
PostPosted: Mon May 16, 2011 7:16 am Up
No these are not the bleed points.
Number 1 is correct
Number 2 is a allen key on the side..
Below the blue clip iirc
Peugeot 206 1.4LX - Sold
Vokswagen Bora 2.0 - Sold
Seat Leon MK2 2.0 TDI - New
PostPosted: Mon May 16, 2011 7:17 am Up
if the filter was pierced that mean you will need a new filter.
Danny.
PostPosted: Mon May 16, 2011 7:20 am Up
Found by searching the forum...
MrrNoName
PostPosted: Mon May 16, 2011 8:31 am Up
The video at the top of that page should be titled "HOW NOT TO FIT AN AIR FILTER", sadly its how 99% of them are fitted, talk about bodging it on lol
Norvvv
PostPosted: Mon May 16, 2011 8:46 am Up
I was just bleeding my one on the thermostat housing for 45 minutes and it was still bubbling a bit and afterwards the Air lock sounded as bad as ever. How long should it take and should I open the thing fully?
2001 1.4lx
PrePlexed 5 door.
Danny.
PostPosted: Mon May 16, 2011 9:18 am Up
Take the cap off the expansion bottle....
Norvvv
PostPosted: Mon May 16, 2011 9:55 am Up
I did...
