Online Now [232]:
Visitors: 231
Today: 16323
Total: 105279754
Forums › The Car › 206 Problems › Dial/electrical issue?
Rob2859
PostPosted: Mon May 16, 2011 5:56 pm Up
This has happened a few times now, I have been sat in the car for a while with the ignition on; it doesn't go into eco mode but the dials make that clicking sound as they wake up and all the lights come on. The millage indicator, stop light and fuel light start flashing (I didn't even know the fuel light could do that). Oh and the dial illumination comes on but only dim.
Here is a slightly poor picture but you get the idea.
Whats going on? :s I have not come across this problem on info before and search failed me.
PostPosted: Tue May 17, 2011 2:34 am Up
Fried BSI?
Rob2859
PostPosted: Tue May 17, 2011 10:15 am Up
Don't say that!
PostPosted: Tue May 17, 2011 10:41 am Up
Battery OR BSI software.
ESP warning light on, does your car even have ESP fitted?
Could also be a loose connection between instrument cluster & BSI
Rob2859
PostPosted: Wed May 18, 2011 7:23 am Up
battery seems pretty good tbh. It has two ESP warning lights, but no it doesn't. Although it has come on before when cornering hard which is quite strange. I will check the cable. Could it be anything else? Also if it is the BSI software what am I looking at cost wise? I don't mind if its just a bug but if the system it slowly courrupting I will not be happy.
PostPosted: Wed May 18, 2011 9:41 am Up
The cluster only has 1 ESP warning light.
The other one will be for the ABS.
Skidding car in a triangle is ESP
Skidding car in a circle is ABS
Rob2859
PostPosted: Fri May 20, 2011 10:46 am Up
Ah that explains it. I will pretend its not there and hope it goes away
