Online Now [332]:
Visitors: 331
Today: 52230
Total: 105946242
Forums › The Car › 206 Problems › New door will it fit????
willb101
PostPosted: Fri May 20, 2011 9:47 am Up
Becuase some little b*****d broke into my car i now need a new window/slash door.
iv seen a door of a 206 gti 180 2005 3dr and wondered if anyone knew if the electric window wiring and the central locking mechanismwould be compatible to my 2007 1.4 look 3dr?
Final thought...get glass cover on your insurance!!!
thanks
Black 206 1.4 8v - 2007
Kill Count
Pigeon - 3
Owl - 1
Rabbit - 6+
Badger - 1 (very nearly 2!!!)
PostPosted: Fri May 20, 2011 9:48 am Up
yes
PostPosted: Fri May 20, 2011 9:53 am Up
You dont even have to remove the door card to change the lock barrel, remove the small black rubber bung & screw a tool in to remove / refit the barrel securing clip Wink
Does your LOOK have deadlocking fitted?
A GTI 180 does, swop the door lock motor from your original door if your car hasnt got deadlocking.
willb101
PostPosted: Fri May 20, 2011 10:15 am Up
it supposedly does have deadlocking (flashes like mad for 30+ secs when pressed lock twice) so should be no problem Smile out of interest what does it do? lol.
thanks a lot
Kill Count
Pigeon - 3
Owl - 1
Rabbit - 6+
PostPosted: Fri May 20, 2011 10:29 am Up
thanks a lot
You DON'T have deadlocking fitted from the description.
Your second button press on the lock button of your remote fob is activating the car park finding function Wink
Your 206 has normal remote central locking, you need to swop the lock motor from inside your original door, you MIGHT also need to swop the wiring loom as well, pretty easy its just plugs & clips.
