Latest: Beduff1977
Overall: 17134
Online Now [1457]:
Visitors: 1456
Today: 116156
Total: 107776337
Forums › The Car › 206 Talk › rear axel
rear axel
moglie
PostPosted: Fri May 20, 2011 12:00 pm Up
hi all i've got a 52 plate 206 quicksilver with abs and my rear axel has now had it ...
has any one converted a rear axel from drum to disk?
just wanted to know how easy it would be and what parts i would need
thanks all moglie
hiya all newbie hear
Matt
PostPosted: Fri May 20, 2011 12:19 pm Up
Trade Rating: +32
think it will be cheaper and easier to just buy a 2nd hand rear disc beam tbh.
cartoonhead
PostPosted: Fri May 20, 2011 12:26 pm Up
been covered once or twice Rolling Eyes
Try Here
moglie
PostPosted: Fri May 20, 2011 12:40 pm Up
i was thinking of getting a gti beam and replacing mine with it just wanted to know if it was a simple swap over and connect?
moglie
PostPosted: Fri May 20, 2011 12:43 pm Up
Try Here
cant find anyting im having a dumb moment lol
cartoonhead
PostPosted: Fri May 20, 2011 1:07 pm Up
4 torx bolts , 2 flexi pipes , 2 hand brake cables , 2 ABS sensor plugs
you will NEED 2 new hand brake cables for a DISK beam and i would recommend 2 new flexi pipes
main problem is making sure you get the right axle with the right ABS plugs as if you get the wrong one your abs light will be on and abs will not work.
moglie
PostPosted: Fri May 20, 2011 1:24 pm Up
cool mate thanks for the info how many different abs connectors are there ?
PostPosted: Fri May 20, 2011 1:25 pm Up
should be 2
moglie
PostPosted: Sat May 21, 2011 1:45 pm Up
will this fit the abs conector is the same colour as mine is that rite lol its off a peugeot 206 grand tourisme mine has drums this 1 has disk's?
how do i tell if its got the rite abs sensor?????
moglie
PostPosted: Sat May 21, 2011 2:38 pm Up
the car that its coming from is a 2000 w plate 1 ! any help would be great
cartoonhead
PostPosted: Sat May 21, 2011 3:28 pm Up
you could.
go to where your buying it from and jack up the rear of your car , take the back wheels off and while your axle is still on your car lie the new axle underneth the back of the car and plug in the abs plugs and then turn the ignition on and see if the abs light comes on.
if the ABS light is on its no good to you
moglie
PostPosted: Sat May 21, 2011 3:49 pm Up
thanks mate is there anyway of telling without being near the car ...cars about 50miles from me he sent me a pic of the abs plug on his
PostPosted: Sat May 21, 2011 3:56 pm Up
you can always reuse your oild hubs+abs sensor
moglie
PostPosted: Sat May 21, 2011 4:00 pm Up
will that work i have drums on mine this 1 im looking at has disks
PostPosted: Sat May 21, 2011 4:10 pm Up
ah....no in this case then
