Posted: Sat May 21, 2011 4:34 am |
I was coming home from work the other night and when i went to put it into 5th it just wouldnt go asif it was blocked. i let it run for about 30 yards in neutral then it went in fine. every now and again this problem occurs but only with 5th gear. Once it is in 5th gear it drives like normal it is just getting it into gear thats the problem.
Any help is appreciated thanks
Posted: Sat May 21, 2011 4:49 am |
Worn linkages possibly.
| 1.4 hdi, 206, Year..2003, 100,000 miles
Mercedes, ML270CDI, 2002, 200,000 miles
BMW K1200RS | |
Posted: Sat May 21, 2011 4:57 am |
worn sychron
Posted: Sat May 21, 2011 5:43 am |
happens to me ocassionally, when it does, rev up to match the revs and put it back into 4th, let it run for a sec and then in to fifth. with mine it happens if i "hang around" in neutral before putting it into fifth, if i go straight from 4th to 5th fast its fine.
Any work you undertake as a result of my posts is done so at your own risk  | |
Posted: Sat May 21, 2011 6:31 am |
cheers, i will keep that in mind. should it get worse i will change the linkages, well i will check them first.
Posted: Sat May 21, 2011 6:41 am |
It's worth changing the gearbox oil too if it hasn't been done for a while.
This definitely helps with smoother changes.
Andy
Posted: Sat May 21, 2011 7:33 am |
| cosmicdance wrote: |
Andy |
Get the oil from Peugeot / Citroen main dealer, its cheap enough.
Putting the wrong / fancy oils in these old PSA gearboxes ends up making things worse
