Latest: jackrox1992
Overall: 17186
Online Now [613]:
Visitors: 612
Today: 152883
Total: 148520499
Forums › The Car › 206 Problems › Rear Fog Light Popping Out
geetarguy85
PostPosted: Mon May 23, 2011 12:46 am Up
Hi Everyone,
My rear fog light keeps popping out and I'm not sure how I can stop this! Currently I've wedged in a couple of broken matchsticks (just the wood! Not the match heads 8O), which seems to be keeping it in place temporarily but obviously this wouldn't pass MOT so I need to sort it before that.
If anybody can help I'd be very grateful.
Thanks!
Ern
PostPosted: Mon May 23, 2011 12:59 am Up
Does the fog light have the metal clip on one side?
PostPosted: Mon May 23, 2011 1:44 am Up
Will it can be fixed by using the plastic zipper tie,lay under the car,you may need to take the spare wheel out for better movement,and while you are there,you will see on the right side of the fog (while you are laying under the back bumper) that there is a square hole,so you can slide the plastic zipper inside that hole,and through the fog light,and tie it with the bumper body,in this case it will be fixed very well,and pass MOT :D,give it a try,it will take few min.
PostPosted: Mon May 23, 2011 2:10 am Up
Most MOT test centers wont bother to check it aslong as it works and its not hanging out you will be fine.
