Latest: tbafonso
Overall: 17130
Online Now [54]:
Visitors: 53
Today: 67964
Total: 103930060
Forums › The Car › 206 Problems › Electronic throttle pedal question
PostPosted: Tue May 24, 2011 4:47 am Up
Scanning our 2007 TU3A I get 'Throttle position % = 12' roughly, even when it is fully up (not being pressed).
Is this normal because on a 2001 corsa and a 2001 punto they both
say TP%=0 when pedal is not pressed?
Any help would be much appreciated. (even from Mr.BSI Very Happy )
PostPosted: Tue May 24, 2011 4:50 am Up
V9977 wrote:
Any help would be appreciated. (even from Mr.BSi Very Happy )
You aint gonna get any help from me Razz
I know NOTHING remember Wink
Never said that.
Cheers anyway.
Anyone else please?
MrrNoName
PostPosted: Tue May 24, 2011 5:13 am Up
seems a little odd to me, is it revving higher then normal at idle?
PostPosted: Tue May 24, 2011 5:14 am Up
Nope. 750 rpm when warm.
PostPosted: Thu May 26, 2011 11:39 am Up
Bump
Any ideas?
macj
PostPosted: Thu May 26, 2011 11:44 am Up
does it read 0% when fully depressed?
PostPosted: Thu May 26, 2011 11:52 am Up
you mean 100%?
I think so, have to re-check.
macj
PostPosted: Thu May 26, 2011 1:31 pm Up
not 100%..... I meant 0% when fully depressed
PostPosted: Thu May 26, 2011 2:06 pm Up
Hmm..
Me check.
PostPosted: Fri May 27, 2011 5:26 am Up
No.
It reads 84% when pressed to the floor (engine off).
11% fully up (engine off).
14% fully up (engine running and warm at 750 rpm idle).
macj
PostPosted: Fri May 27, 2011 9:11 am Up
sounds fine to me.... the values are correct on the throttle position
PostPosted: Fri May 27, 2011 9:47 am Up
Excellent. Thanks.
I thought previous owner might have gone for a re-map.
There seems to be a slight 'jolt' of the engine 1 out of 10 times when
stationary in neutral and then pressing the pedal down even slightly.
Checked the engine mounts and they seem to be OK.
macj
PostPosted: Fri May 27, 2011 10:50 am Up
I cant see any related issues here. I think that you need to check mounts and linkages as you said
PostPosted: Fri May 27, 2011 11:01 am Up
What are linkages?
