Latest: Worthy967
Overall: 17143
Online Now [588]:
Visitors: 587
Today: 102608
Total: 115002881
Forums › The Car › 206 Talk › 3rd brake light help
furryhobnob
PostPosted: Sat May 28, 2011 4:06 am Up
Morning people I was wondering how to remove my 3rd brake light, I've undone both bolts but it won't move, is it just being stubborn or is there something I'm missing
PostPosted: Sat May 28, 2011 4:17 am Up
Give it a gently tap on the screws and it should come away, they tend to stick.
PostPosted: Sat May 28, 2011 4:18 am Up
It will be stuck because they never get removed.
Put the nuts back on a couple of turns to protect the studs then smack them with a little hammer to free the light.
furryhobnob
PostPosted: Sat May 28, 2011 4:21 am Up
Cheers guys I thought it was just being stubborn, didn't want to give it a whack and break something
furryhobnob
PostPosted: Sat May 28, 2011 4:28 am Up
I'm hitting it as hard as I can and it's not budging!
PostPosted: Sat May 28, 2011 4:33 am Up
could always try and gently lever it out mate or if you can, disconnect the wire and water hose and see if that helps, I found mine easy to remove but a pain to re-fit
furryhobnob
PostPosted: Sat May 28, 2011 4:35 am Up
I've tried levering it mate the bloody thing won't move at all, how do I disconnect the wire and hose with the light still in?
PostPosted: Sat May 28, 2011 4:36 am Up
I used a screw driver with a cloth to prize it out but did brake it. If your planing on not using it you could do that
furryhobnob
PostPosted: Sat May 28, 2011 4:37 am Up
Yeah I'm not too bothered if it breaks to be honest, gonna give that a bash now, cheers mate
PostPosted: Sat May 28, 2011 4:43 am Up
Just have to prise it, get a very small screwdriver and wedge it in careful not to break the red cover it's easier said then done.
furryhobnob
PostPosted: Sat May 28, 2011 5:42 am Up
Done it finally, thanks guys
Dabamash
PostPosted: Sat May 28, 2011 6:11 am Up
Staff - Daba
Lol, you guys make it sound so hard. I just used a pair of pliers, put the nose up against the bolt, then used the lip with the rubber seal on it as leverage. Just push down on the handle of the pliers and the light comes right out Smile
PostPosted: Sat May 28, 2011 6:39 am Up
Depends if it's stuck / seized it's going to be different for everyone. Even after removing the tailgate a few that I've taken off put up a right fight.
furryhobnob
PostPosted: Sat May 28, 2011 6:48 am Up
And put up a fight it did, I won though lol Wink
Dabamash
PostPosted: Sat May 28, 2011 6:50 am Up
Staff - Daba
Nah, my first one was bloody impossible. Just used the pliers. The amount of leverage you can get will pop even the most solid of lights out.
