Latest: tbafonso
Overall: 17130
Online Now [136]:
Visitors: 135
Today: 11242
Total: 103941656
Forums › The Car › 206 Problems › car will not start or looses power to start.
supercows
PostPosted: Sun May 29, 2011 4:22 am Up
hi there,
i keep having the issue whereby my car needles on the speedo are sticking e.g the fuel needle will raise
and then i suddenly have a cut out in power to actually start the engine.
it does seem to be able to be rectified if i disconnect the baterry and then re-conect it and the engine will then start when i turn the ignition.
has anyone else experienced this before
could this be an alternator problem?
many thanks
supercows
apjs87
PostPosted: Sun May 29, 2011 5:48 am Up
get a new battery
No longer a 206 owner
Astra H sxi. 1.7Cdti
PostPosted: Sun May 29, 2011 6:07 am Up
check the earthing point connected to the battery,and if you have a multimeter check the voltage of your battery when you start it,if it reads 8-9 Volts,then you need a new battery.
PostPosted: Sun May 29, 2011 6:47 am Up
bad earthing, this happens to me quite a few time
supercows
PostPosted: Sun May 29, 2011 7:00 am Up
thanks so much guys....
have had this on a few occasions after ive been on a good run tho with the sub an amp connected up
and put it down to them draining the battery....
though i have got a battery charger, is it worth giving the battery a bit of a boost with this?? as i thought agood run out would sustain the sub and amp useage....
i take it its the battery head connector points that i should give a quick clean and rub down?
supercows
PostPosted: Sun May 29, 2011 7:29 am Up
No.
Anything bellow 12.25V means the battery has had it.
PostPosted: Sun May 29, 2011 7:35 am Up
nothing to do with the amp/battery, it is due to the loosen connection...
richpowell91
PostPosted: Sun May 29, 2011 7:39 am Up
No.
It doesnt necessarilly mean the batteries had it and you need to buy a new one, when i first brought my car the battery was flat to the point it was reading 3v. I then charged it the following day put back on the car and was fine. And even after the car not being used for 4 months and going flat again, since using the car regulary ive not had a problem since.
So its always worth charging the battery up and trying it again. Obviously though if it goes flat within a few days and no problem is found with the alternator or earthing points then it points to a new battery.
PostPosted: Sun May 29, 2011 7:45 am Up
richpowell91 wrote:
No.
Yes obviously if you leave the car standing for months it could fall to 3V or even less.
But for a normal-run car and with the alternator working properly (13.5V+) it should not fall
below 12.25 even after weeks of non-use.
Otherwise the capacity has fallen to the point of being useless.
PostPosted: Sun May 29, 2011 7:49 am Up
3v reading from a 12v battery?
i have never ever seen this before lol
it must have sit on the shelf for few years? lol
mine sit still for 4 months still got 11.9v lol
PostPosted: Sun May 29, 2011 8:01 am Up
You had no load sitting it on the shelf.
Some cars have clocks, alarms, BSi listening for keys etc.
Still, 3V means there's something very wrong there I agree. Even after months.
PostPosted: Sun May 29, 2011 8:07 am Up
Re-read your post.
If it was fitted, yours sounds about right.
richpowell91
PostPosted: Sun May 29, 2011 8:20 am Up
Yeh i was as surprised as you about how low the reading was, i brought the car off a family friend with no mot tax etc, and was told the last decent run it had was a whole year before i brought it.
I think the only reason why its still going strong is that its a Varta battery so not your cheap £20 battery from a local motor factor.
PostPosted: Sun May 29, 2011 8:25 am Up
no wonder they put 5 year warrantly on their battery.
always worth to paid a bit more!
PostPosted: Sun May 29, 2011 8:29 am Up
Varta Batteries Thumbs Up
