Posted: Sun May 29, 2011 4:35 pm |
![](images/spacer.gif) |
Posted: Sun May 29, 2011 5:17 pm |
that the pedal sensor.
did you adjust the cable right?
Posted: Mon May 30, 2011 12:46 am |
Ah right. Thanks. I'm not sure if I did or not. I just put the sensor back where it's normally clipped in. What should I have done to adjust the cable?
Posted: Tue May 31, 2011 4:01 am |
My local garage is closed today so had to go to Peugeot themselves as I need the car for a week's road trip. Their diagnosis is a new accelerator cable required...£120 in total.
Posted: Tue May 31, 2011 4:36 am |
hahahaha what a joke! dont even bother, im sure you can find another garage to do it for half that!
| No longer a 206 owner
Astra H sxi. 1.7Cdti | |
Posted: Tue May 31, 2011 5:26 am |
Maybe. I need the car ASAP though; they had the part in so it'll at least get done today. I've been to several garages when I've needed work doing ASAP and they've always had to order parts in meaning the job has sometimes taken until the next day to complete.
Posted: Tue May 31, 2011 10:27 am |
unclip the cable.
pull it as far as you can until you feel the resistant from the cable,
then put the clip back.
Posted: Thu Jan 05, 2012 3:32 am |
Hi,
Did the replacement fix your issue?
Thanks O
Posted: Sat Jan 07, 2012 12:51 pm |
Changed my cable today took me 20mins! What a result car back to normal! The old cable had stretched and basically wasn't opening the butter fly valve enough, resulting in not enough revs causing car to be like a bag of s**t.
