Latest: Beduff1977
Overall: 17134
Online Now [327]:
Visitors: 326
Today: 207733
Total: 107609300
Forums › The Car › 206 Problems › HELP! FAN NOT WORKING
d00b
PostPosted: Mon May 30, 2011 8:26 am Up
hi can anyone help me please......?
my fan went on my pug 206 55 plate, i replaced relays and the fan with a second hand 1 which i know works perfectly, but its still not kicking in when the engine gets hot :O(
please does anyone know what the problem is and how i can fix it?
many thanks
d00bsx
PostPosted: Mon May 30, 2011 8:45 am Up
is the coolant reading correct on the dash? maybe coolant sensor?
d00b
PostPosted: Mon May 30, 2011 9:02 am Up
once the car in in motion or the internal fans r on full (hot) the temp goes down and stays at around 90 but when the car is stationary the temp rises :O(
the original fan was completely seized too
crazy mazey carz
PostPosted: Mon May 30, 2011 9:17 am Up
im lost.
Does the slow and/or fast speed fan come on at all? slow usually at 93, fast at 100+.
if the slow fan doesnt come on it could also be the resistor below the relays.
omricn
PostPosted: Mon May 30, 2011 9:27 am Up
I just posted a similar problem on my pug.. think we have the same issue..
d00b
PostPosted: Mon May 30, 2011 9:36 am Up
sorry lol the main engine fan doesnt come on at all i have to use the internal fans to cool the engine down
read thru the later posts and tried turnin on my AC but nothin either.
when the original main engine fan went my car overheated and the thermostat siezed which i changed, after putting a perfectly workin 2nd hand fan in and changed the relays it still doesnt work
sorry if i confused u lol any ideas?
crazy mazey carz
PostPosted: Mon May 30, 2011 9:41 am Up
did you check the connections to the relay. no corrosion?
also not sure but is there a fuse for the fan? maybe that?
www.206info.co.uk/Foru...=fuse.html
d00b
PostPosted: Mon May 30, 2011 9:52 am Up
Yes there was slight corrosion but had it all sorted and cleaned all fuses were fine checked every single 1 lol put new relays in and still nothin :O(
could it possibly be a temp sensor? i dont know alot about cars but ive been told there r 3 in the car i dont where or which 1 it maybe :O(
crazy mazey carz
PostPosted: Mon May 30, 2011 9:55 am Up
Maybe temp sensor if its showing a wrong reading. What engine do you have?
d00b
PostPosted: Mon May 30, 2011 10:02 am Up
1.4 :O)
crazy mazey carz
perry081064
PostPosted: Mon May 30, 2011 10:03 am Up
think mine needs one of these too , anyone got a part number and price for these ?
(2.0 HDI)
206 2.0 HDI
Darkness
PostPosted: Mon May 30, 2011 10:04 am Up
PostPosted: Mon May 30, 2011 10:13 am Up
Aren't there two coolant sensors on TU engined cars? Maybe the sensor that tells the ECU to switch on the fan doesn't work. On my GTi the fan fuse is in the fuse box under the bonnet. I think it's a 40 amp fuse.
Does the fan come on when the air conditioning is switched on? I think you said you'd checked the relays but did you check the condition of the wiring? In 8 years I'd never heard my fan come on at high speed. Although my car didn't sit in traffic much I'm sure I'd have heard if it was working. My relays were rather crusty and the +ve wiring was actually broken at the teminal under the relay. The condition of the wiring wasn't apprent from just checking the relay though.
d00b
PostPosted: Mon May 30, 2011 10:23 am Up
checked all of that had new relays checked all fuses and had the slight corrosion and wirin sorted but havent checked the sensor to the ECU....:O/ would i have to go to a garage to get that checked?
ive always heard my fan kick in ever since ive had the car from the dealer its alway been quite noisy. :O)
crazy mazey carz
PostPosted: Mon May 30, 2011 10:34 am Up
So the wiring is 100% definately attached to the terminal under the relay? I imagine if it was plugged into PlanetPeugeot or whatever it's called it would tell you what information is coming out of the sensor.
