Latest: tbafonso
Overall: 17130
Online Now [165]:
Visitors: 164
Today: 11193
Total: 103255228
Forums › The Car › 206 Problems › bump stops?
bump stops?
20619d
PostPosted: Wed Jun 01, 2011 3:38 pm Up
hi found a 206cc at crediton scrape so got rear bump stops of it. there just twist and pull off. now went to fit to mine and found to blocks of metal bolted where the bump stops go. do i unbolt them then will fit or no?
Matt
PostPosted: Wed Jun 01, 2011 3:43 pm Up
Trade Rating: +32
Whats a "bump stop" ?
PostPosted: Wed Jun 01, 2011 3:48 pm Up
It's a bump stop Laughing
PostPosted: Wed Jun 01, 2011 3:50 pm Up
So the 206cc bump stops weren't attached to a small block of metal held onto the car with a torx bolt?
20619d
PostPosted: Wed Jun 01, 2011 3:53 pm Up
nope so take it i cant fit them
PostPosted: Wed Jun 01, 2011 4:38 pm Up
The only bump-stops I know are the plastic 'rings' that fit in the front shock-absorber struts
for when it has ran-out of piston-movement (bottoming-out) and you get the characteristic 'bang' in a pothole etc.
PostPosted: Thu Jun 02, 2011 12:52 am Up
Only rear bumpstops on 206s I have seen are the pull out type, never seen ones with a torx in them :s
anthony_839
PostPosted: Thu Jun 02, 2011 1:08 am Up
d/w bout it you dont need them Very Happy lol i dont run any one my astra
euroed astra
Sezticle
PostPosted: Thu Jun 02, 2011 1:43 am Up
I cut mine in half Very Happy
WIP Thread: CLICK HERE
arronmee1990
PostPosted: Thu Jun 02, 2011 1:44 am Up
The bracket for the bump stop is held in with a torx bolt. I had to change mine as the bracket had rusted away and the bump stop fell out!
My Project Thread
PostPosted: Thu Jun 02, 2011 1:22 pm Up
it is used to protect your suspension from bottoming out.
high end dampers normally have internal bump stop
imjeeves
PostPosted: Thu Jun 02, 2011 1:28 pm Up
the gti ones are held in with a torx. Bump stop are important as they stop your rear suspension from bottoming out. If your rear shox do it often enough they will break
Lecktorious
PostPosted: Thu Jun 02, 2011 1:31 pm Up
Trade Rating: +59
Btw, car went well at the Reivers rally on Sunday Wink seen it on Friday night too at Abbey St Bathans but never clocked the car!
'98 Nile Blue 306 GTi 6
imjeeves
PostPosted: Thu Jun 02, 2011 3:12 pm Up
Thanks mate. Car was actually running rough all weekend, three cylinders on friday and sat then down on power on the sunday. My gearbox blew up the week before the rally as well so I was running a standard gti box. The ratios were not great with a big gap between second and third. Bit of work to get it going 100% again
