Latest: tbafonso
Overall: 17130
Online Now [353]:
Visitors: 352
Today: 2842
Total: 103364169
Forums › The Car › 206 Problems › What have I done wrong, injectors?
sheehan879
PostPosted: Thu Jun 02, 2011 6:06 am Up
Hi all,
to cut a long story short I recently changed head gasket as I had the common oil leak. All was well for a week doing short journeys to work etc.. Went on a long run and after about an hour I could smell fuel, turned out an injector was leaking. I thought this was probably because I used universal o rings on the injector seals. Bought new ones from Peugeot (£30) fit them and set of back home. About 40 mins in the car cut out and now wont start.
I thought it was the injector seals again because when I put my hand round the back and put a little pressure on the injectors they leaked again. But would this stop the car from starting?
I changed the seals again taking care to fit them properly (with a little oil to ease them in) but it still wont start. Any Ideas? I have fuel in the rail but dont know if it is getting to the engine.
Its a 2001 206 1.4 manual by the way. Any help would be greatly appreciated.
Cheers,
Jase
Cheers,\r\n\r\nJase
sheehan879
PostPosted: Thu Jun 02, 2011 6:08 am Up
forgot to say, it tries to fire up but keeps on turning over.
Cheers,\r\n\r\nJase
Seb
Staff - Seb
If they are leaking they're either broken or you really can't have put them back in properly. They aren't the easiest things to stuff back into place remember.
JE_180
PostPosted: Thu Jun 02, 2011 6:14 am Up
I may be reading it wrong but do they still leak? If not the engine may be flooded?
NICKST
PostPosted: Thu Jun 02, 2011 6:38 am Up
Might sound silly but get a mate to tow it while you try bump starting it worked for me once.
PostPosted: Thu Jun 02, 2011 8:36 am Up
Don't, as you can cause damage.
nakednakeddave
PostPosted: Thu Jun 02, 2011 8:52 am Up
try the multiplug that goes into the injector rail. when i did the headgasket i never plugged it in properly (because its a pain in the ass to reach) and it just kept turning over and not firing....
but works fine now
fat exhaust, dodgy rusty bonnet, stickers and steels....
KRU KREW
leigh_boy
PostPosted: Sun Jun 05, 2011 2:44 am Up
pres big red button, and check all connections / fitment off injectors
*DEAD*206 Gti 138
Toyota Celica T sport 205 BHP
PostPosted: Sun Jun 05, 2011 3:01 am Up
Take the plugs out and see if they are all covered in fuel. Or try adding a bit of throttle on start up to help clear the fuel out.
