Latest: Stu-mill
Overall: 17131
Online Now [254]:
Visitors: 253
Today: 42333
Total: 104678581
Forums › The Car › 206 Problems › Front coil spring broken
deanparkr
PostPosted: Sun Jun 12, 2011 12:43 pm Up
Just got back home after having the RAC out. Heard a really loud knock noise when turning a corner. RAC investigated the fault to the front side coil spring and towed me home.
Very nice service by the RAC!
Will be taking the car to garages tomorrow and just wondered what 206-ers thought the price should be for replacement springs.
Also, is it worth doing the other springs at the same time?
Thanks for any advice Smile
2002 1.4LX
kieron
PostPosted: Sun Jun 12, 2011 12:49 pm Up
You may awell because they could be a slight hight difference due to were, also if its just as old it could go anytime soon so the whole job will have to be done again and could be dangerouse and cause a accident to you and other road users
Account suspended
deanparkr
PostPosted: Sun Jun 12, 2011 12:55 pm Up
That seems to make sense. I'll try and get them both done in that case.
Kudos to RAC today though. First time I've called break-down people and its certainly worth having the cover!
2002 1.4LX
PostPosted: Sun Jun 12, 2011 1:30 pm Up
spring is cheap.
mostly is the labour cost
PostPosted: Sun Jun 12, 2011 1:36 pm Up
Where abouts are you? I have one you can have for free
I had mine fail on an MOT didn't take long to do myself.
PostPosted: Sun Jun 12, 2011 1:45 pm Up
I'd replace the top mounts and bearing too. If they are slightly seized then that could have contrbuted towards the spring breaking. That with speed bumps and cold weather.
PostPosted: Sun Jun 12, 2011 2:23 pm Up
Better off replacing the pair of them.
