Online Now [559]:
Visitors: 558
Today: 10567
Total: 105587571
Forums › The Car › 206 Talk › Bigger Wheels = Loss of Speed???
Go to page Previous  1, 2
doughboy5
PostPosted: Tue Jun 07, 2011 8:48 am Up
low profile tyres. obviously the lower you go the closer it will be to your old wheel size.
206 GTi
Buggy
PostPosted: Tue Jun 07, 2011 11:18 am Up
Nice little tool for checking options:
Arrow www.rimsntires.com/specs.jsp
Buggy
An old fart in yet another mid-life crisis car
PostPosted: Tue Jun 07, 2011 11:51 am Up
Just add nos. The girls will think your cool, and you might get laid.
Or they might think your a p***k with a little willy.
willb101
PostPosted: Tue Jun 07, 2011 11:56 am Up
Cheers for the advice
Black 206 1.4 8v - 2007
Kill Count
Pigeon - 3
Owl - 1
Rabbit - 6+
Badger - 1 (very nearly 2!!!)
Coolspot
PostPosted: Tue Jun 07, 2011 12:38 pm Up
I thought that i was loosing speed from the 17" i have fitted i beleive the car has 15" steel in the garage. What i found using my Sat Nav was the speed is set faster that actual and putting bigger wheels now means the speed it says actually is the speed i am doing.
When we go past a matrix board at just over 30 it the pug it will flash up< in any other car with standard wheels we can do just about 35 before its activated but the satnav is alway saying we are going past it at 31mph
206 3dr 1.4 GLX modified slightly, Lowered 35mm on full Gmax kit, 17" AEZ xylo alloys 205/45/17, 3.5" Savage back box,
PostPosted: Tue Jun 07, 2011 1:40 pm Up
Rob2859 wrote:
Bigger wheels higher the gearing. You may have lost some acceleration but gained slightly on top speed.
You won't gain a higher top speed because it won't be at peak power at top speed even as standard.
Page 2 of 2
