Latest: tbafonso
Overall: 17130
Online Now [56]:
Visitors: 55
Today: 41374
Total: 104396624
Forums › The Car › Request a how-to › how to perform an immobiliser reset
Forum IndexRequest a how-to
jimmy
PostPosted: Sat Jul 02, 2011 11:30 am Reply with quote Up
my 16 GLX wont start! To cut a long story short, I have no power going to the fuel pump. After replacing the fuel relay and testing the fuel pump (which works fine) I want to reset the immobiliser.
Any ideas on how to do a reset?
I have disconnected the battery for the night and hope in the morning everything will be reset when I re-connect the battery.
Are there any procedures with the key, ignition etc??
cheers \r\nJimmy
PostPosted: Sat Jul 02, 2011 12:11 pm Reply with quote Up
Search soft boot bsi
PostPosted: Sat Jul 02, 2011 12:25 pm Reply with quote Up
You can't reset the immobiliser per say as its in the BSI. The only thing you can do is softboot the BSI. And since you have had the battery off overnight you will have done that.
The ring around the ignition is prone to failing.
Ash
PostPosted: Sat Jul 02, 2011 1:16 pm Reply with quote Up
Check your fuses.
  Quick Reply
Username:
Message:
Quote the last message
