![](themes/base/images/spacer.gif) |
![](themes/base/images/titleTL.gif) |
Forums › The Car › 206 Problems › rev counter locking at 1100 revs then dying |
![](themes/base/images/titleTR.gif) |
![](themes/base/images/titleBL.gif) |
![](themes/base/images/titleBR.gif) |
![](themes/base/images/forums/otl.gif) |
Posted: Fri Jun 17, 2011 7:31 am |
hi, my rev counter has recently decided to die but then all of a sudden works slightly for a few seconds, itll sometimes rev up to about 1100 lock and keep clicking there, then just drop to zero. iv recently had the crank pulley seal changed and iv been told the rev counter sensor is located there so i dont know if that could be anything to do with it. iv checked the connection behind the cluster and its secure but im not sure exactly the location of the sensor on the on the crankpulley seal or how to get to it, any ideas on a quick fix, could it be dodgey cluster or sensor??
cheers connor
x reg 206 1.4Lx
| | ![](images/spacer.gif) |
Posted: Fri Jun 17, 2011 8:03 am |
U might need to take the clocks apart and Just pull the rev needle out bit to loosen it up I had to do this once.
Welcome btw.
| Image removed due to size
focus st 3 with pro alloy intercooler, 3" mongoose down pipe, 200 cell sports cat and mongoose cat back, collins bov, dreamscience dsci cold air intake,focus rs injectors,focus rs oil cooler,dreamscience dsci tuneing platform mod X map,focus rs clutch & flywheel, rs fuel pump, polly bushes in wish bones rear axal and suspension white line front and rear arb, eibach pro street s suspension. | |
Posted: Sat Jun 18, 2011 8:59 am |
cheers mate il try that now, if it works your a life saver, been annoying me non stop, and the police are spot checking all my local streets
Posted: Sat Jun 18, 2011 9:34 am |
no it didnt work, im gonna buy a new cluster
| ![](themes/base/images/forums/otr.gif) |
