Latest: jackrox1992
Overall: 17186
Online Now [979]:
Visitors: 978
Today: 54985
Total: 148016617
Forums › The Car › 206 Problems › GTi 180 clutch refitting help
sri16v
PostPosted: Mon Jun 20, 2011 3:30 am Up
Right Ive got the box off new clutch in, all ready to go, problem is I cant get the engine and box to line up, Ive had it on and off several times but cant seem to get further than an inch away.
Input shaft is lined up correctly, drivers side driveshaft is going on, just seem to be struggling with the final inch or so, box is back off now on the floor ready for attempt no.2.
Any tips?
My release bearing was in pieces all over the gearbox casing, managed to take a few blades off the pressure plate as well as damage the clutch springs, doh!
Also anyone thinking of doing a 180 clutch DIY, dont bother, what a job just to remove the gearbox, tight is not the word
2004 GTi 180
cartoonhead
PostPosted: Mon Jun 20, 2011 4:50 am Up
not sure if the 180 has the dowles around the meeting point of the box to the engine but if it has are they all right in ?
sri16v
PostPosted: Mon Jun 20, 2011 5:41 am Up
yep it has the dowels as well as some awkward to get to bell housing bolts, behind the manifold, they were fun to get to.
Im about an inch away from the the dowels going in, going to have another go this afternoon, Im thinking maybe the engine will need to be raised or lowered a bit, currently on chocks of wood, using a jack and manpower to line it up.
I would take the driverside driveshaft out, to make it easier but cant undo the hub bolt as the subframe is down and its too tight too undo even with a jack supporting the hub
2004 GTi 180
kieron
PostPosted: Mon Jun 20, 2011 6:01 am Up
Have a word with kyle he can do them in around 4-5 hours
Account suspended
dannyN
PostPosted: Mon Jun 20, 2011 6:06 am Up
I did a clutch a few days ago and was a night mare .. im used to working on jap cars and the pug was a right pain in the a**e .. i couldnt get my drivers side drive shaft out and still had my sub frame on i managed it after two attempts and after crushing my hand but just keep adjusting the engine height and angle and you should be fine Smile Good luck
cartoonhead
PostPosted: Mon Jun 20, 2011 6:37 am Up
get someone to turn the drivers side hub slowly as you push the box in to see if its the driveshaft splines stopping it.
sri16v
PostPosted: Tue Jun 21, 2011 6:55 am Up
managed to get it on after, absolute pain of a job, I think I could do it around 6 hours now I know where everything is, ended up taking the gearbox mount off the gearbox to get a bit more clearance. A bit of pushing with legs and she slid on.
Only problem now is went to top the gearbox oil up and it was leaking out the passenger drive shaft, so going to have to get the driveshaft located properly.
Is there a circlip on the driveshaft or does it just need pushing in a bit further?
2004 GTi 180
sri16v
PostPosted: Wed Jun 22, 2011 4:31 am Up
anyone know about the driveshafts going into the box? Havent had time to look, but are they held in by a circlip on the passenger side? or does mine just need pushing in a bit further?
2004 GTi 180
cartoonhead
PostPosted: Wed Jun 22, 2011 5:35 am Up
is it not just a round spring clip that holds it in ?
just a pice of meatal that kinda looks like a pice of coat hanger wrapped around a groove in the splines.
if you pull the shaft back out get a new seal and change that while the shafts out incase its that whats split and it will save pulling it out again Wink
mattievrs
PostPosted: Wed Jun 22, 2011 5:53 am Up
Check the oil seal and im not 100% on the 180 set up, but does the shaft fit into a bracket on the engine? Is the driveshaft located far enouh into the bracket?
NO LONGER ACTIVE ON THE FORUM
cartoonhead
PostPosted: Wed Jun 22, 2011 6:21 am Up
thats the drivers side one with the 2x 11mm bolts that are stoopidly long Wink
ive allways hated them Sad
mattievrs
PostPosted: Wed Jun 22, 2011 6:50 am Up
yeah youre right mate. Been a while since i had to do a shaft on a 206!
sri16v
PostPosted: Wed Jun 22, 2011 8:28 am Up
I dont think its the seal, from underneath it looks as though the driveshaft isnt far enough into the box, as though it needs to go another inch or so.
Sounds like it just needs pushing further in then, might have a go later if I get time.
2004 GTi 180
cartoonhead
PostPosted: Wed Jun 22, 2011 8:41 am Up
i normaly put the end in to the box as far as it will go then have the shaft lined up and have a hand on the treaded end that goes thru the hub and one on the shaft it's self and use it's own weight to tap it in Wink
PostPosted: Wed Jun 22, 2011 9:04 am Up
Guide on how to fit and remove, but you'll have to email me for the gearbox one because its bigger then 256kb
