Online Now [299]:
Visitors: 298
Today: 5944
Total: 105269397
Forums › The Car › 206 Problems › Start > Rev > Die
Start > Rev > Die
myke
PostPosted: Wed Jun 22, 2011 8:14 am Up
Hi guys,
I've searched but can't find anything using
'revs stalls'
'revs high stall'
So idk..
A couple of times this has happened now, I start the car, the engine revs really high and then stalls itself, without me touching anything. It's embarassing for me and it can't be good for the car Embarassed I'm thinking of cleaning the ICV? Will that be it?
& Also sometimes when I'm driving, the car feels like it loses power until I put my foot on the pedal a bit further and it bursts back into life, any ideas?
Thanks guys
PostPosted: Wed Jun 22, 2011 8:17 am Up
Had it fault read?
myke
PostPosted: Wed Jun 22, 2011 8:23 am Up
No I've never thought of it Razz
PostPosted: Wed Jun 22, 2011 8:42 am Up
Maybe you should Razz
Danny.
PostPosted: Wed Jun 22, 2011 8:45 am Up
Sounds like the ICV give it a good clean also where it attahces to the throttle body.... May even be worth getting a new one if it loosk worn.
Peugeot 206 1.4LX - Sold
Vokswagen Bora 2.0 - Sold
Seat Leon MK2 2.0 TDI - New
myke
PostPosted: Wed Jun 22, 2011 9:51 am Up
Alright, thanks guys, I'll give this a go and post back Very Happy
Ape
PostPosted: Wed Jun 22, 2011 10:02 am Up
Yep, clean the stepper motor (ICV), and take the MAP sensor out and give it a good clean.
myke
PostPosted: Wed Jun 22, 2011 10:03 am Up
What does the MAP sensor do? I always see it being mentioned
PostPosted: Wed Jun 22, 2011 12:36 pm Up
Quote::
A MAP (Manifold Absolute Pressure) Sensor is a micromechanical sensor that measures the absolute pressure in the intake manifold and compares it with a reference vacuum, not with the ambient pressure. This enables the air mass to be precisely defined.
myke
PostPosted: Wed Jun 22, 2011 3:14 pm Up
Very technical Razz
206info.co.uk/Forums/v.../t=72.html
Lee if I follow that guide, it says about unplugging the sensor whilst the engines running, I thought it buggers the car up if you unplug a sensor whilst the battery is connected?
PostPosted: Wed Jun 22, 2011 5:03 pm Up
Nah you can unplug sensors when the engine is running. You can unplug the coolant sensor to test the fan Smile
myke
PostPosted: Wed Jun 22, 2011 5:38 pm Up
Ah ok awesome Very Happy
cheers I'll post back
