Latest: SA01
Overall: 17138
Online Now [8125]:
Visitors: 8124
Today: 265007
Total: 111579317
Forums › The Car › 206 Problems › GTI 180 not so horny....
Go to page Previous  1, 2
PostPosted: Thu Jun 23, 2011 3:13 pm Up
Just get a bit of wire and join the wires back up
L5_UKS
PostPosted: Thu Jun 23, 2011 3:30 pm Up
Where abouts is the wire though? by the fuse box? how can you get to the wire?
PostPosted: Thu Jun 23, 2011 3:31 pm Up
take the drivers wheel arch liner off. The horn is there, stick your head uunder the car
L5_UKS
PostPosted: Thu Jun 23, 2011 3:36 pm Up
Okay nice one ill see if i can sort it out tomorrow if not ill be back for more advice ha! Smile
kingdom200
PostPosted: Thu Jun 23, 2011 4:00 pm Up
not much luck with this one have you luke
PUG1OFF Cat Cams/ ECU project
L5_UKS
PostPosted: Thu Jun 23, 2011 4:14 pm Up
No mate its becoming abit of a nightmare, sometimes i think why did i have another peugeot ha, should be all sorted soon though only little things Smile
Rob2859
PostPosted: Thu Jun 23, 2011 5:55 pm Up
just get an air horn and have done with Wink
PostPosted: Fri Jun 24, 2011 3:49 am Up
Lee wrote:
Wires will have corroded and snapped on the connector. Very common
What He Said
Done a 04 plate the other week, both wires corroded of the back of the plug.
Lucky I have new plugs spare in the tool box Cool
jayz206gti
PostPosted: Sun Dec 23, 2012 4:25 am Up
Is it the actual connectors to the horn that corrode? Mine has been mute for a while now and i should really sort it out
Upgraded from 138 to 180
Jack123
PostPosted: Sun Dec 23, 2012 6:27 am Up
Get it sorted before the MOT, Failure right there.
Cherry Red 206 1.1 99'
Wanted List;
Crystal Headlights.
PM Me if you are selling!
jayz206gti
PostPosted: Sun Dec 23, 2012 6:38 am Up
#statetheobvious
PostPosted: Sun Dec 23, 2012 12:26 pm Up
Plug is just a standard Junior Power Timer plug.
bezford
PostPosted: Sun Dec 23, 2012 5:55 pm Up
Whats all the fuss guys just take the wires off.clean the horn and the wires forks trim an inch or two from the wires making sure u get clean copper to clip to and its not too short then just crimp a new spade connector on each wire then click the wires back on the horn...it should take 5mins no more
But...if there isnt enuf wire length then add a few inches from an old peice of wire...TIP...put the spades on the extension wires before you extend the too short old wires...then to join the new and old wires strip both ends and slide them into a tube crimp with the bare copper tips wound together and the tube crimp crimped over the wires for a permanent repair....
Also spray the whole horn and near wiring with a water dispersant/water proofing electrical issolating spray but not wd40 as it causes corrosion and electrical staticing...
R.HYDE
Page 2 of 2
