Posted: Thu Jul 21, 2011 9:48 am |
I was going to lower the bar myself but seen as I didn't have a spring compressor it needed to be done at a garage anyway. So I thought I would save myself the effort of unseizing the torsion bar myself and let a garage do it.
I found out after that they had done it via the spline method. How likely is it to cause problems?
I have read the how-to on lowering the other way but do not know how to adjust it with this method.
Posted: Thu Jul 21, 2011 10:01 am |
Try it the way my mate says to. Throw a few bags of cement in the boot to drop it to required height & then heat the bars/arms up with a blowtorch and then just throw a bucket of cold water over it
Posted: Thu Jul 21, 2011 10:06 am |
| LeeThr wrote: |
Try it the way my mate says to. Throw a few bags of cement in the boot to drop it to required height & then heat the bars/arms up with a blowtorch and then just throw a bucket of cold water over it  |
The poor man's lowering guide but clever non the less !
Posted: Thu Jul 21, 2011 10:08 am |
| LeeThr wrote: |
| Daily Hack - 2013 Audi A3 Sport | |
Posted: Thu Jul 21, 2011 10:12 am |
| brimbo wrote: |
| LeeThr wrote: |
The poor man's lowering guide but clever non the less ! |
Haha, Brainiac, The lazy mans guide
Posted: Thu Jul 21, 2011 10:37 am |
if you are worried you can always replace the bearing.
Posted: Thu Jul 21, 2011 10:43 am |
Bucket of water and then you've got to kneel or lie in the puddle...Nice.
Posted: Thu Jul 21, 2011 11:15 am |
What do you mean by spline method.
Remove bars and rotate round 1 or two?
If they are done with a dummy shocker then it is the correct way to do it.
Otherwise take it back because you have been ripped off
| 206 180 rally car in progress. I may not be perfect but there are parts of me that are f£%$ing brilliant | |
Posted: Thu Jul 21, 2011 12:34 pm |
| LeeThr wrote: |
F**K that.
Posted: Sat Jul 23, 2011 5:39 pm |
oh dear. I think it will be fine. Nobody has actually said why it is wrong anyway
