Latest: tebas93089
Overall: 17179
Online Now [158]:
Visitors: 157
Today: 25663
Total: 138333856
Forums › The Car › 206 Problems › Pug 206 Angel eyes
Pug 206 Angel eyes
DJ_M4rko
PostPosted: Sun Jun 26, 2011 7:41 am Up
In fact I have a problem with my angel eyes, do not work at all. Do I have to disassemble the overall unit headlight bulb to change 4 or has a different way .. Thanks for your help
Sve vise je previse !
PostPosted: Sun Jun 26, 2011 7:54 am Up
Have you wired them up?
DJ_M4rko
PostPosted: Sun Jun 26, 2011 8:02 am Up
Of course, I know only that no other lamp is not working
PostPosted: Sun Jun 26, 2011 8:05 am Up
do you have to earth them??
(ie not earthed on original loom)
DJ_M4rko
PostPosted: Sun Jun 26, 2011 12:01 pm Up
Are connected to the position of the lights ... mean plus and minus
PostPosted: Sun Jun 26, 2011 12:09 pm Up
If it is all wired up correctly, and there is voltage going to the LED's, and there is earthing. Then it probably will need the LED's replacing, which means heating them up and splitting them apart.
I'm very surprised that all 4 rings have blown at the same time though Confused
DJ_M4rko
PostPosted: Sun Jun 26, 2011 12:34 pm Up
for a long time does not work, I am most interested in whether I have to disassemble the whole headlight to replace four light bulbs. (I am thinking that keeps them warm hair dryer and disassembled)
PostPosted: Sun Jun 26, 2011 12:43 pm Up
Yes you do. Heat them up in the oven or with a hair dryer or heat gun, then you split them in half
DJ_M4rko
PostPosted: Sun Jun 26, 2011 12:45 pm Up
Thank you very much for your help
PostPosted: Sun Jun 26, 2011 12:50 pm Up
If you put them in the oven, 100oC for about 20 minutes
