Latest: jackrox1992
Overall: 17186
Online Now [1055]:
Visitors: 1055
Today: 101298
Total: 148864846
Forums › The Car › 206 Problems › manifold rattle
manifold rattle
20619d
PostPosted: Thu Jun 30, 2011 7:51 am Up
my exhurst has a rattle and have found it. its where the pipe joins to the manifold. the little spring part are lose. do i need replace anything or just loads wd40 and do it up?
any help be great
o and only rattles when idles but not when i drive along
Kersh
PostPosted: Thu Jun 30, 2011 7:56 am Up
soo your exhaust clamp is loose..? just tighten it up Confused
Member number: 36
20619d
PostPosted: Thu Jun 30, 2011 8:07 am Up
it the one with the springs one it. the bit that on manifold
PostPosted: Thu Jun 30, 2011 8:12 am Up
Probably a bit rusted.
Try spraying it with WD40 and tightening it up. Otherwise you'll need to replace the bolts & springs at some point.
20619d
PostPosted: Thu Jun 30, 2011 8:13 am Up
that part that lose
