Online Now [296]:
Visitors: 295
Today: 18997
Total: 105282425
Forums › The Car › 206 Problems › bottom end knock i think.
mjsroofing
PostPosted: Mon Jul 04, 2011 7:40 am Up
is there any comman faults with these every one,
Its a 1.4 hdi 03 plate and its done just under 165k,
the knock is a little tiny and only apparant on tick over it sounds nice while reving it lighty.
I'm sure I've heard something about a bottom pulley going on these engines and sounding like this, am i right or barking up the wrong tree.
Any help would be appreciated, thanks Mark.
Mark
03 206 1.4 hdi 3 door 187k
02 transit 100 280 196k
04 renault Laguna 80k
09 transit 115 300 43k.
leigh_boy
PostPosted: Tue Jul 05, 2011 12:51 am Up
video of the sound will help , rod nock will sound really bad when you give it some revs.
*DEAD*206 Gti 138
Toyota Celica T sport 205 BHP
mjsroofing
PostPosted: Tue Jul 05, 2011 11:57 am Up
its my mrs car so catching up with the car is hard sometimes, but its defo a bottom end knock.
Mark
skard
PostPosted: Tue Jul 05, 2011 12:53 pm Up
is your aux belt tensioner bouncing on idle and the noise dies when revs are applied?
i had this recently and it was the alternator pulley causing the vibration.
mjsroofing
PostPosted: Tue Jul 05, 2011 12:59 pm Up
I'll check that out , was there an easy way to test this mate
Mark
skard
PostPosted: Tue Jul 05, 2011 1:25 pm Up
in the end i bought a new alternator which resolved it. i believe you may be able to have the pulley swapped out but it could also be the internal bearing, thus i just bought a new unit seeing as the old one was 8 years old anyway.
however, before that i replaced the aux. belt, tensioner and crank pulley in vain but the noise still existed.
if you put the aircon or electrics on you'll likely hear the noise die down a tad, if this is the same problem. on mine, as soon as the RPM went above tickover the noise went.
if you think it's the crank pulley, have a look at it side on and see if the damper has cracks in it or anything visible of note.
mjsroofing
just checked the aux belt tensioner and they seem fine, BUT i did notice that the loom going to the ecu was rubbing on the top pulley ( power steering is it ), so taped it up to the other part of the loom going around the front of the engine so that its safe, and now i cant hear the knock, is it because I just cant hear it from being next to the engine for a while, or could there be a possible chance that it could of been earthing one of the wires on the pulley and causeing over fueling or someting.
ANY HOW, BIG NOTICE TO ALL 1.4 HDI AND POSSIBLE 2.0 HDI OWNERS, CHECK WIRING LOOM, IS IT RUBBING ON TOP PULLY.
Mark
skard
PostPosted: Tue Jul 05, 2011 1:29 pm Up
hopefully you've found the source of the problem.
the fan belt has probably been rubbing against the wiring?
mjsroofing
PostPosted: Wed Jul 06, 2011 1:26 am Up
yes the wiring was rubbing on the belt/pulley and had caused a small amount of damage, couldnt say if it had made any difference to the knocking sound though, think the sound difference that think i could hear while i was out there last night could of bben any think , my ears most prop! or the engine warming up, but you know what its like when your trying to hear for something.
Mark
mjsroofing
PostPosted: Fri Jul 08, 2011 2:10 am Up
ok been out a few times and knocking is still there, finding the wiring loom rubbing on the aux belt was a good thing but didnt solve any thing, has any one changed the bottom end shells on here, any idea of price etc.
Mark
