Posted: Tue Jul 05, 2011 10:16 am |
Hi Guys,
My engine has a constant ticking coming from the rocker. One of my mates has said that its the things that the cams push down are a bit warn?
Would that sound about right?
If so, is it an expensive job? I want to get my car back to sounding sweet, and hopefully get the power back it came with.
All I need to do is give it a service and sort this ticking, and it should be right as rain
Any help would be much appreciated.
Posted: Tue Jul 05, 2011 10:21 am |
+1 Mine is the same. Stupid old piece of crap!
spike_202 wrote: |
My Powerflow is quite loud but then again it's on ITBs and has a decat. |
Audi Sport  | |
Posted: Tue Jul 05, 2011 10:24 am |
yes they are. hyraulic lifter aren't cheap. and you will have to renew the whole set each time. 8 for 8v and 16 for 16v
but just to make sure you oil is good and is enough
More to the point though, I used Wynns Valve lifter concentrate and it quietened it down a bit.
spike_202 wrote: |
Audi Sport  | |
Posted: Tue Jul 05, 2011 10:29 am |
Howey wrote: |
More to the point though, I used Wynns Valve lifter concentrate and it quietened it down a bit. |
mine was quite quiet after oil change each time.
Posted: Tue Jul 05, 2011 10:34 am |
Howey wrote: |
My oil is about half on the dipstick, so it does need a bit more, but that'll get done with the service.
If the service doesnt help that much, does the valve lifter go in with the oil?
Posted: Tue Jul 05, 2011 10:49 am |
Out of technical curiosity, How does that valve lifter stuff work?
Posted: Tue Jul 05, 2011 10:50 am |
Valve lifter concentrate just gets added in with the oil
Im not sure Rob, I think its witchcraft
spike_202 wrote: |
Audi Sport  | |
Posted: Tue Jul 05, 2011 11:12 am |
www.wynns.uk.com/pDocs...N_MSDS.pdf
check this out.
INFORMATION ON INGREDIENTS
NAME CAS NO EINICS/ELINCS MIN/MAX SYMBOL R-PHRASES
2-(2-butoxyethoxy)ethanol; diethylene glycol monobutyl ether 112-34-5 203-961-6 1 <= C < 2.5 % Xi R36
4-methyl-2-pentanol 108-11-2 203-551-7 1 <= C< 2.5 % Xi R10, R37
Distillates (petroleum), hydrotreated heavy naphthenic; Baseoil - unspecified 64742-52-5 265-155-0 > 75 %
Zink alkyl dithiofosfaat 68649-42-3 272-028-3 1 <= C < 2.5 % Xi,N R38, R41, R51/53
cyclohexanone 108-94-1 203-631-1 1 <= C < 2.5 % Xn R10, R20
cut it short, snake oil
or just put some ZDDP into your oil and thensee your cat die.
Posted: Tue Jul 05, 2011 11:18 am |
Sorry Seabook, What does that list of ingredients mean?
spike_202 wrote: |
Audi Sport  | |
Posted: Tue Jul 05, 2011 11:24 am |
Howey wrote: |
Sorry Seabook, What does that list of ingredients mean? |
2-(2-butoxyethoxy)ethanol; diethylene glycol monobutyl ether, 4-methyl-2-pentanol and cyclohexanone use to take away water from the fuel and engine oil. quite a common component in most fuel additives.
is just basic stock mineral oil.
Zink alkyl dithiofosfaat is ZDDP, used to have about 5% to 10% in the engine oil before cat. was introduced; it is used as an anti wear agent. apparently it is toxic to the cat. so modern engine oil have <2% of that present. apparant they replace that with other thing but not as effective?
most competition oil will have at least 5% of that present anyway.
Posted: Tue Jul 05, 2011 11:25 am |
Seabook wrote: |
http://www.wynns.uk.com/pDocs/76864_EN_MSDS.pdf
check this out.
or just put some ZDDP into your oil and thensee your cat die. |
wtf is that form made for? Most of its random jargon.
Posted: Tue Jul 05, 2011 11:26 am |
Seabook wrote: |
Howey wrote: |
most competition oil will have at least 5% of that present anyway. |
So your saying dont use it as everything I need is in the oil?
Posted: Tue Jul 05, 2011 11:31 am |
i never used any oil additive or fuel additive.
however, many people like to add redex or what so ever in their oil or petrol frequently, you just can't ignore the placebo effect.
Posted: Tue Jul 05, 2011 11:33 am |
This is the first car where Ive had to worry about things and i havent got a clue!
I wont be putting any additives in at least until the service is done.
I know you said the valve lifters can be expensive, but dont suppose you know a rough figure?
